FIRST TIME TOY OWNER's 3.4 SWAP THREAD
Old Dec 15, 2008 | 08:48 PM
syber_kowboy's Avatar
Rob is right the cost isn't worth it. I would recommend making an adapter by cutting the body plugs out of the donor and cutting the body plugs off the old 3.0 harness. Then you can build the adapter on your coffee table and solder all the connections. It makes it a lot more reliable and you can remove it if you need to fix something or want to swap it into something else. I bet you can get some of the wiring diagrams from guys on the forum.
Old Dec 15, 2008 | 08:51 PM
If you want the 90 EWD's I'll zip em up and host them somewhere for ya.
Old Dec 15, 2008 | 11:26 PM
MotoXJunky's Avatar
That would be awesome..
I plan on doing all autometer gauges and speedo etc. i dont want the stock 4runner gauge cluster. Im doing custom dash. Fiberwerx.com midsize dash
Old Dec 16, 2008 | 08:38 AM
90 4runner wiring diagrams minus AC and Cruise
Old Dec 16, 2008 | 09:32 AM
  #25
RaginYota's Avatar
how different is the 4runner EWD compared to a pick-up?? I understand that the runner will hav rear wiper..ect..ect...??
Old Dec 16, 2008 | 09:55 AM
  #26
I think as far as the body harness go they are the same. I'm not positive but I'm pretty sure. The interior wiring is different because of the rear window, the wiper, the speakers, etc but I'm pretty sure the engine and body plugs are the same from truck to truck. Actually I'm 99% positive because I used body plugs from a 90 auto pickup in my swap and they were exactly the same except it wasn't 4wd.
Old Dec 16, 2008 | 09:05 PM
  #27
MotoXJunky's Avatar
http://www.chaosfab.com/92300.html
Thats the suspension im putting on the front.
http://www.off-roadweb.com/features/...4x4/index.html
this is my ideal rear suspesion... i wanna keep my rear intact cuz i want to make it available for a blow-up mattress so i can camp
any opinions?
Old Dec 17, 2008 | 08:39 AM
  #28
RobD's Avatar
None of that matters.
All you're doing is wiring up the engine computer. Wipers, etc, are not controlled by the ECU. You're looking at wiring up things like the speed sensor and power. Nothing else.
My engine/ECU came from a 97 Tacoma. No problems with the 91 4Runner.
Old Dec 17, 2008 | 12:39 PM
  #29
A New High's Avatar
Does it matter if the 3.4 is out of a 2wd or 4wd? Also I heard the 99 and up have bigger injectors and the MAF is changed? And the engine ECU is totally separate from the tranny controller, so I can use a 3.4(that had an auto behind it) in front of my R150F without any wiring problems, right?
Sorry, /hyjack
Old Dec 17, 2008 | 04:14 PM
  #30
MotoXJunky's Avatar
I spent half the day trying to get my hub and rotor off and was unsuccessful (ok not half the day but a good part of my evening). im trying to take out my front diff i must be retarded or something
Old Dec 18, 2008 | 09:31 AM
  #31
Sorry, /hyjack
You really want to get a 4WD ECM and harness. I think the MAF came in 2000 but I don't know about a separate tranny controller. I think you can use an auto ECM and harness with a manual by tricking it into thinking it's in neutral the whole time but someone wrote something about that causing mapping issues or some such thing. Sorry there are some many "I think" "something" "someone"s, but all the specifics seem to blend together these days.
Old Dec 18, 2008 | 03:03 PM
  #32
MotoXJunky's Avatar
Rob or Kowboy.. i found a 3.4l 4runner engine with ecu and uncut wireharness with all the accessories. it was from an auto for around 1.5K should i jump on it? If it DOESNT have an ecu will it be easy to get one i need?
Old Dec 18, 2008 | 03:53 PM
  #33
scuba's Avatar
Its safe to get the ecu with the same motor from the donor to not f things up...if you cant find one for same year/tranny, you might be down a while looking for said ecu...
But 1500...how many miles...?
Old Dec 18, 2008 | 03:59 PM
  #34
RobD's Avatar
If you find the complete engine with ECU and uncut harness, yes, jump on it. Or, better yet, just buy it. That won't be as painful as when you land on the engine.
Old Dec 18, 2008 | 04:01 PM
  #35
scuba's Avatar
Old Dec 18, 2008 | 04:09 PM
  #36
mastacox's Avatar
Just thought I'd jump in and say that the 99-up injectors are not bigger, their design is just a little bit different and they are just a plastic body. pre-99 injectors and post-99 injectors are completely interchangeable AFAIK. Hard to say if they're better or worse (the plastic bodies can crack if clamped incorrectly), but their flow ratings are basically the same.
Not sure about MAF, but they did start using throttle by wire in 2001 I think, which could change things in the swap.
Old Dec 18, 2008 | 04:18 PM
  #37
1500 for a 3.4 with low miles is a pretty good deal but like scuba said, If you don't get the correct ECU with the purchase you'll be searching quite a bit. An auto ECU will go for at least $100. You also have to consider the tranny. I spent about $2k for a motor, tranny, accessories, crossmember, and all the little bits and pieces I needed. You might be able to find a better deal. Just FYI
Old Dec 18, 2008 | 04:47 PM
  #38
MotoXJunky's Avatar
thanks. it has 52,XXX miles on it I emailed dude about the ECU so we'll see what he says
Old Dec 18, 2008 | 04:54 PM
  #39
mt_goat's Avatar
No throttle by wire on my 2001, I think it was after 2002, like 03 or mid 02.
Old Dec 18, 2008 | 05:12 PM
  #40
MotoXJunky's Avatar
you guys know anybody that has attempted a 4.7l swap?
