A/c Help!
Old Aug 17, 2008 | 03:36 PM
odonekanobe's Avatar
Would a fix be to just swap in the later amplifier, instead of trying to get ours to work?
Old Aug 17, 2008 | 04:08 PM
mt_goat's Avatar
Some have done it that way.
Old Aug 18, 2008 | 03:54 PM
Is it an easy swap?
Old Aug 18, 2008 | 05:25 PM
jskijoe's Avatar
If I'm going to keep my R12 system, I pretty much have to keep my amplifier for the current system. Yet I'm still unclear on what I have to do differently to get it to work with my new engine if I'm keeping it the same. I'm sure I'll see it when I tear into it but I'd welcome any enlightenment on what the amplifier does and how it interfaces during an engine swap.
Old Jun 25, 2012 | 06:43 AM
  #25
rbmoomba's Avatar
if you run a thermostat switch to the evaporator, (and in-line with the clutch power wire) it will cycle on and off and prevent freeze ups automatically. I just finished getting mine working. I wasn't about to swap out every sensor/switch and the amplifier. Make sure the hot wire is attached to an "ignition on" wire so you don't kill your battery if you forget to turn it off. Good luck
Old Jun 25, 2012 | 09:25 AM
  #26
vasinvictor's Avatar
You just bumped an inactive 4 year old thread BTW there's the sticky on the subject now RIGHT HERE
Old Jul 19, 2012 | 04:51 PM
  #27
rbmoomba's Avatar
Sorry, Vasinvictor. I guess that hurt your feelings or it affected you in some way. I'll look at the dates a little closer.
Badlander
Oct 10, 2015 08:05 PM
Ktm526
Oct 7, 2015 05:14 AM
bryan34w
12
Sep 30, 2015 02:50 PM
BimmerSage
Sep 17, 2015 11:48 PM
Tacoma1313
Sep 8, 2015 01:27 PM
