3.4 wiring help needed
#129
recently brought truck to be tuned and even with a 14gph meth nozzle i am still a little lean up top so i am in search of supra injectors.
the question i have is fuel pump based. when i upgrade injectors to whatever they may be( i think i read 305cc supra injectors? i dont know what year etc yet though) will i need more fuel pump to push them? the swap truck is a 1994 toyota pickup with a 3.0.
#131
hey guys, i have been having this problem for quite a while. my ac works great but my truck doesnt seem to know that the compressor is engaged so my idle drops ridiculously low. hamish_18 led me to notice that i have 2pins missing that are suppose to be there to tell the ecu that the a/c clutch is engaged. Not only have i forgotten what pins but i do not what i am suppose to bring to those pins?
#132
Check the sticky thread, there's one I did for the A/C. There is no provision for A/C idle up in those wires you speak of. My idle dips for a split second, but always returns to 550-600. I've considered wiring in an idle up valve tied to the compressor clutch wire similar to the 3vze.
#134
Mine doesn't either. It is always 500-600 rpm no matter compressor on or off. Check how I laid out the wiring, and see if you have it wired that way. You shouldn't have any problems.
