3.4 swap o2 Sensors i need help /w wiring question
Old Dec 26, 2011 | 12:07 PM
Countryhick's Avatar
I have the o2 sensors and the wires off the harness EXCEPT
The wires are cut right at the motor and i need to resplice them into it i have a complete wiring diagram. Problem is.
The o2 sensors up stream n down stream both have a solid brown wire. And a white /w blue stripe. Which makes me confused on doing the wiring. except.
both brown wires meet up before they hit the ecu. Both white n blue meet up before the ecu. But do they send the same signals?
Whos got ideas for me or answers if im right that it shouldnt matter which matching wires i hook up?
Old Dec 26, 2011 | 04:02 PM
32views !! no answer?
Old Dec 26, 2011 | 08:17 PM
dntsdad's Avatar
they are just power and ground for the sensors. You can join them.
Old Dec 26, 2011 | 09:28 PM
sixstringslut's Avatar
Kind of confused b/c most I have seen are four wire O2 sensors. If just two then should not be a problem tying together same colors.
Old Dec 27, 2011 | 06:34 AM
dntsdad's Avatar
they are 4 wire........at least mine are. Power, ground, heated feed, O2 data to ecm.
Old Dec 27, 2011 | 01:08 PM
I meant 4 matching colors I know how many they have thanks guys I figured out yesterday power n ground
jb451
7
Oct 7, 2022 06:58 AM
some drunk guy
Aug 3, 2021 06:09 PM
MadMax48
Mar 3, 2020 10:33 AM
LJR
Sep 5, 2015 06:02 AM
