3.4 auto => maual trans???
Old Mar 2, 2009 | 04:38 PM
904_runner's Avatar
Yes i looked for it but i didn't find any results for doing such.
Also with doing this swap, if i use the 3.0 flywheel will the 3.0 starter work?
Old Mar 3, 2009 | 02:57 PM
Dan.3's Avatar
yep and Ill look for the auto ecu with manual set up later on.
Old Mar 16, 2009 | 08:30 PM
904_runner's Avatar
Okay so im in a rut with this..
i am having problems with finding an ecu... im about ready to call up TAP recycling tomorrow and ordering from them.
My only concern is that the auto harness might not plug into the mt ecu they send me..
if that is the case is there a place where i can buy each individual plug and rewire that so it will plug into the ecu?
Old Mar 17, 2009 | 01:57 PM
904_runner's Avatar
Okay i have a problem i have been searching for a freaking ecu for a while now and i cannot get one..
This guy Doug at a shop in rancho cordova has been searching through books for me seeing if the ecu's he has would work.
He ended up not having an ecu out of a 99 tacoma mt.
But he said he could sell me a uncut harness out of a 96 4runner 3.4 manual trans with the ecu for $250.
My question is, should i do this. I will essential have two harnesses then, so if anything on the 96 harness didn't work on my motor i could always swap the connectors correct?
If i buy this will the 96harness and ecu work with this motor.. Smog/CEL/ ETC............
Please respond to this cause if so i need to order it today so i can get it this week.
Thanks.
-Mike
Old Mar 30, 2009 | 07:25 AM
  #25
904_runner's Avatar
okay i did not buy that particular harness/ecu..
I am trying to make this ecu work temp, until i can get a M/T ecu..
Does anyone know where i can get one for cheap,
If the auto ecu will work for now,
Or if a 99 tacoma 2wd 3.4L manual trans ecu will work, (i can get one for $100)
Old Mar 30, 2009 | 09:49 AM
  #26
TMZ's Avatar
TMZ
Just a heads up, if you pick up a 4runner ecu of the same year. Even tho the plugs are the same, the wires are in differant locations in the plugs. This means you can use a 4runner ecu, but will have to repin the harness. Both at the ecu and plugs that plug into the body harness.
Old Mar 30, 2009 | 10:23 AM
  #27
904_runner's Avatar
Yea..
i have a harness/ecu out of a 99 tacoma.
So im searching for one out of a 99 tacoma MT 3.4L
Idk if a 2wd ecu would work, i would prefer to have a 4wd ecu. but im still searching for now..
I am trying to make the auto ecu i have work temporally..
Old Mar 30, 2009 | 03:23 PM
  #28
TMZ's Avatar
TMZ
I have a 98 tacoma 4x4 M/T harness and ECU for $250. I will do the harness and conversion for $550 shipped
akamon808
3.4 Swaps
Dec 16, 2015 08:45 PM
Chumlee780
Nov 13, 2015 03:18 PM
AndYota
Aug 10, 2015 09:19 AM
ghostmoney
Aug 6, 2015 08:40 AM
this_guy
Jul 31, 2015 01:27 PM
