What to lube the speedo cable with?
Old Nov 14, 2002 | 05:46 AM
JustAnotherJodieFE's Avatar
I have one of the squealy speedo cables and have removed it to lube it with something. I'd rather not use something like WD-40, I don't want to go through this again. Is something like axle grease better? Does anyone know what the factory calls for?
Old Nov 14, 2002 | 12:40 PM
Jay's Avatar
Jay
If I remember correctly, doesnt the cable pull out of the Sheath?
If Yes:
You could try pulling it out and coating the cable in "White Lithium" grease, then slide it back in.
Although, I think partially why it makes the noise is there is some wear to the "Sheath" from the inside. Replacing the enitre cable is best.
Jay
Old Nov 14, 2002 | 01:34 PM
obxfishn's Avatar
Another good lubricant for stuff like that is called LUBRI-PLATE. I have had excellent results using this product on a speedo-cable in a older Toyota truck. I necer heard another noise from the cable again. Good luck.
Mike
Old Nov 14, 2002 | 01:41 PM
Jay's Avatar
Jay
Yes.... Lubri-plate is great stuff.... Thats actually what I had in my mind when I said "White Lithium". But now thinking about it, I dont think Lubri-plate is a Lithium.
USE Lubri-plate on the speedo cable.
Jay
Old Nov 14, 2002 | 07:23 PM
Adam F's Avatar
Any tips on removing the guage cluster to get to the cable in a 1st gen 4R? I've got some squeeling going on and a burn out dash light, so I need to get to the bottom of it.
Old Nov 19, 2002 | 03:09 PM
Well, before I could read the previous posts, I pulled the cable out of it's sheath and coated it with white lithium grease. The sqealing hadn't been going on too long and I couldn't see any evidence of the cable fraying. Hopefully the sheathing will last for quite awhile with this. The noise is gone now.
kawazx636
Oct 6, 2021 03:03 PM
Truckwithoutaname
Oct 3, 2015 03:41 PM
charlie_fong
Sep 27, 2015 10:06 PM
rmill05
Sep 27, 2015 01:43 PM
Rcbc92
Sep 26, 2015 03:00 PM
