transmission shop
transmission shop
can anyone recomend a tranny shop in the DC/MD/VA area. I have a feeling its something simple and dont want to hear "you need a new tranny" $$$$. it might be a solenoid, TPS or kickdown cable.
You could try adjusting the transmission's "kick down cable" there at the throttle body to remove the slack in it, as this will improve the shifting.
It just may be that the cable has become so loose that it is not going into OD.
Other than that, have you checked the transmission fluid level lately... the correct way ??
Info for both of these suggestions can be found with the "search" feature and good luck!
I adjusted the cable and thats when this all started. but i also did a fluid/filter change to the tranny ...and fluid is good
Originally Posted by YeloSub7
my tranny has major slippage and wanna know where to get it rebuilt
crammit442
7
Nov 29, 2017 12:30 PM
Tigbucket
Jul 30, 2015 07:29 PM
madxman21
Jul 9, 2015 10:26 AM
