tourqe converter service
Old May 16, 2004 | 04:19 PM
burntaco's Avatar
Question tourqe converter service
i have the auto trans out of my 95 v-6 x-cab 4x4 p/u because of a rear main leak.changed the seal and was wondering if i should drain and refill the tq converter while the trans is out.if so how much does it hold.i am planning to flush the trans after it is reinstalled.the truck had trans problems when i got it(would not shift into o/d)along with various other problems.i've only driven the truck twice,once when i bought it and again after i fixed a water leak(waterpump).on the second trip it seemed to shift into o/d fine.anyway we'll see when it's back together.
Old May 17, 2004 | 07:59 PM
TechWrench's Avatar
It can't hurt, but because of design, you won't be able to get all the oil out. Maybe about 70%. Just follow the refill directions for the trans after you reinstall. If you drain the trans pan, you will need about 7-9 quarts of fluid to refill. Make sure you use the right fluid for your unit, check the manual.
kawazx636
Oct 6, 2021 03:03 PM
coryc85
Dec 5, 2015 08:42 AM
Dale Johnston
11
Oct 31, 2015 10:22 PM
Cycles
Sep 29, 2015 06:37 AM
Scotttekoch
Sep 28, 2015 10:30 PM
