Tight turns, and a horrible, horrible sound.
Old Apr 16, 2005 | 09:55 PM
ATP4984's Avatar
So, last winter I decided to do some donuts in the parking lot when it was covered in a few inches of snow. I was in 4WD at the time. I think this was a very bad idea.
Ever since, when making very tight turns I hear the worst possible sound you can imagine coming from your vehicle coming up from the front right wheel. It's a metallic grinding, banging, popping, snapping, screeching sound. When I come out of the turn, it goes away.
What the hell did I do to my truck?
btw, 93 4Runner
Old Apr 16, 2005 | 09:58 PM
ChickenLover's Avatar
Smear grease on your steering stops.
Old Apr 16, 2005 | 10:04 PM
colsoncj's Avatar
Yup that sounds like it.... they're the little metal tabs on the bottom of the control arms i think... contact a little rubber nub, if its still there....
Old Apr 16, 2005 | 11:58 PM
93YODER's Avatar
I had the same problem with mine when I bought it,
Very simple fix is to smear thick axle grease on all 8 streering stops on the knuckle,''I did this about two months ago,and it hasnt accrued again sence''or you can buy new new nylon caps from the stealer that go on the end of each steering stop bolt,and this will fix your problem.
Old Apr 17, 2005 | 12:21 AM
bike4miles's Avatar
Yea, mines doing that again. Gota greas thoes limaters after a winter of snow and ice.
Old Apr 17, 2005 | 08:13 AM
Randomness's Avatar
In 4wd, with the wheel turned to lock, you shouldn't be hammering the gas. Not good for the CV's, and probably not good for anything...
Old Apr 17, 2005 | 05:28 PM
elnido's Avatar
I heard a mechanic call the sound the "Toyota Turn"
Old Apr 17, 2005 | 07:53 PM
Brendan's Avatar
Old Apr 17, 2005 | 11:17 PM
ATP4984's Avatar
Thanks for the pic and advice.
raptor510
Aug 19, 2015 02:15 PM
genuinegemini
Aug 3, 2015 04:56 PM
Snort
Jul 19, 2015 07:03 AM
kvanzandt1
Jul 18, 2015 10:15 AM
Poncho0206
Jul 10, 2015 06:21 PM
