Running hot with heater on
Old Mar 30, 2005 | 08:17 PM
Yamaha+Toyota=Fun's Avatar
I have a 22re and am aware of the temp overshoot problem with this motor. After doing my HG I noticed that if I had my heater on full blast and I went up a decent sized hill that my temp guage would start to climb a couple needle widths. Usually at the top of the hill or sometimes halfway up the needle on the temp guage would just drop suddenly back to the normal spot. Is this caused by the thermostat paritally closing or could it be a clog/air lock in the heating system? I have read a few articals on this, but noone thus far has had the rising and dropping of the temp guage.
Thanks
Old Mar 30, 2005 | 08:24 PM
superjoe83's Avatar
what kind of t-stat do you have, does it do the same thing with the heat off?
Old Mar 30, 2005 | 08:32 PM
photoleif's Avatar
...and with the heat on, do you get HOT air or lukewarm or cold? have you pulled the thermostat to see if it performs to spec?
Old Mar 31, 2005 | 09:51 AM
sefus's Avatar
i read somewhere that withteh Toyota heater system, your temp will actually go up withteh heater on. Wish i remembered exactly why.
Old Mar 31, 2005 | 12:22 PM
PirateFins's Avatar
I saw a post on here about a month or so ago with the same problem and someone explained that issue (Roger Brown?). He said because of the design of the return from the heater core that is a normal occurance and has nothing to do with the temp overshoot. Mine did the same exact thing and with the 2-stage t-stat and all of the air removed from the system it is better. Do a search I know I saw it.
edit.....
take a look at 4Crawlers page on the issue http://www.4crawler.com/4x4/CheapTri...tml#Thermostat
Old Apr 1, 2005 | 04:28 PM
frankenrunner's Avatar
Guest
Lightbulb
you should check to make sure that all of the air is bled out of the coolant system; that the radiator & cooling fan are "cycling" &, of course, that the coolant is topped up.
Old Apr 1, 2005 | 05:16 PM
jimbo74's Avatar
check out the link piratefins posted.. its from roger brown's website.... the dual-stage thermostat fixed all the exact same problems i was having on my 85 22r
have had no problems since....
Old Apr 2, 2005 | 11:34 PM
Im gonna go pick up that thermostat next week. I also think im gonna have my cooling system cleaning too. I think its starting to get clogged in spots. Anyone have any idea what kinda cost I'd be looking at for having that done? Thanks for all the posts.
the1998sr5
15
Jul 14, 2020 08:35 PM
BeMiceElf
Oct 10, 2015 09:40 PM
msane99
Jul 17, 2015 10:13 AM
Poncho0206
Jul 10, 2015 06:21 PM
HRDC0R19
Jul 5, 2015 06:43 PM
