rear windshield wiper motor
Old Jul 30, 2004 | 05:16 AM
Chapman88SR5's Avatar
does anyone have anyidea of why this wouldnt be working? nothing on it works not the wiper itself and not the wiper fluid deal.
btw its on my 87 4runner
Old Jul 30, 2004 | 05:23 AM
TDiddy's Avatar
Is it getting juice? Relay/Fuse maybe? I don't know if its on the same power as the front wipers or fluid pump or not.
Old Jul 30, 2004 | 05:52 AM
the front ones work if that means ne thing
Old Aug 4, 2004 | 05:40 PM
Lt. Dan's Avatar
Cool
Two possible reasons I can think of, (1) Check the connection under the moulding to the left of the tailgate, it is the same one you would have to dissconnect if you were to remove the "canopy". It might have wiggled loose.
(2) One of the bolts on the driver side that holds down the "canopy" is also holding down a switch that disables the power window and the rear wiper assembly, when removed. If that switch is bad, or you have the wrong size bolt in there, you will get the same problem.
Good luck!!
Old Aug 4, 2004 | 06:15 PM
Good luck!!
hey i think ur number 2 reason is correct! cuz i knew about the one near the tailgate and checked that one, but i never knew about the other one.
i removed the top not to long ago and put it back on the other day and didnt put all the bolts in so i bet ur right there
thanks!
incase u were wondering the only reason i wanted this to work is cuz theres so many stupid tailgaters here and it drives me crazy, so i just wanted to be able to move the wiper fluid sprayer thing so i could spray the tailgaters
Old Aug 9, 2004 | 12:43 PM
Lt. Dan's Avatar
Thumbs up
LOL! What a great idea! That will teach those Tailgating scum....Keep us posted on how that works, I just might have to try that.
Old Aug 9, 2004 | 12:52 PM
will do, if the tailgaters pass me, the ones up front are turned around also
Flying91
45
Apr 11, 2024 04:39 PM
Sep 4, 2015 09:27 AM
msane99
Jul 17, 2015 10:13 AM
AaronM
Jul 8, 2015 07:15 PM
toyoda8488
Jul 5, 2015 10:18 PM
