Oil Change Mishap
Old Oct 29, 2004 | 11:27 AM
UTKtacoma's Avatar
Oil Change Mishap
I was changing the oil on my 98 Tacoma and while pouring the new oil in, accidentally bump the funnel, spilling around a quart of oil all over my engine bay. Most of the oil seemed to fall straight through the engine bay, landing on the frame, but a good bit got all over my alternator. I wiped everything down as best as I could, but am worried it may have done some damage to the alternator. Is there anything I need to do? Is this something to worry about or not? This may sound like a stupid question, but it has got me worried. Thanks
Old Oct 29, 2004 | 11:46 AM
4Hummer's Avatar
Sounds like you gave yourself a free oil spray. I can't see it causing any harm
Whenever I get my truck Oil sprayed the cover the whole vechile top to bottom.
Im sure someone else will chime in here .
Old Oct 29, 2004 | 01:00 PM
PirateFins's Avatar
My front main seal went bad and the fan coated everything in the engine bay with oil, including the alt. It was so bad I could see any of the shinny metal. I cleaned everything with Gunk engine bright and everything is working just fine.
Old Oct 29, 2004 | 01:21 PM
UTKtacoma's Avatar
I went out and started it up and it seems to be running as well as always, and best of all, it is looking much cleaner. Thanks for the info guys.
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
calderp
Engine Swaps
Aug 16, 2016 05:15 PM
calderp
Jul 27, 2015 09:58 AM
horunner1x
Jul 10, 2015 06:33 AM
