fuel filter location
Old May 14, 2003 | 01:25 PM
Can anyone tell me where the fuel filter is located on my 1996 4runner w/2.7 4-cyl? I can't seem to locate this thing.
Old May 14, 2003 | 01:57 PM
kctopher's Avatar
Co-Founder/Administrator
I was the same way when I first changed my oil in my 2k..
Im not sure for the 4Cyl, but chances are its something you will probably have to reach from the bottom, and you might have to remove you skid plate to get a visual..
Gee, I guess that didnt help much..
Cheers,
Chris
Old May 14, 2003 | 02:32 PM
SLOYOTA's Avatar
The fuel filter is tucked under the intake manifold and attached to the engine block. Its a PIA to get to. Removing the driver's side font wheel and the covers in the wheel well will help you get better access to the filter. It took me a good 2 hours to replace the filter. Look in the tech section or do a search, there is a good write up on how to do the job on a 22RE engine. Its pretty much the same procedure for the 3RZ.
Old May 14, 2003 | 03:12 PM
Thanx guys, I'll give it a shot on saturday!
smthwsn357
May 1, 2024 07:28 AM
Eggslinger
Jun 8, 2019 03:32 PM
pyramid
Jul 30, 2015 10:05 AM
Hiluxtrucha
Jul 22, 2015 10:00 AM
Fundy Rider
Jul 16, 2015 01:35 AM
