Door lock
Old Sep 27, 2003 | 02:12 PM
Mindburnt's Avatar
Door lock
My driver side door lock works fine, but it wont unlock from the outside when using the key. Which part in the door lock do I need to replace?
Old Sep 28, 2003 | 05:49 PM
Mindburnt's Avatar
anyone?
Old Sep 29, 2003 | 04:52 PM
95_4X4Runner's Avatar
You'll have to take it apart and look at it. Maybe one of the linkages has popped loose.
For me, the hardest part of removing the door panel the first time was the door handle. Remove the screw, push the whole handle forward about 1/4", then it'll come out. Unhook the clip on the linkage, and it's off. The rest is pretty easy to figure out. You'll have to remove the plastic covering behind the door panel also, then get a light and look up the the inside of the door handle when turning the outside lock.
If you don't see anything obvious, you can always take apart the passenger side and make comparisons.
Let us know what you find.
westonian18
May 1, 2020 06:38 AM
mussy01
Dec 13, 2016 08:20 PM
r3dfish
54
May 16, 2016 10:31 PM
shisha1999
Sep 20, 2015 11:44 AM
moonpie
Jul 31, 2015 11:58 PM
