Belts Squeaking?
Old Apr 26, 2005 | 12:39 PM
2002 SportEdition's Avatar
Belts Squeaking?
Whenever I wash the truck (regular wash and/or engine wash) or after the truck sitting under rain for sometimes, when you first start it up, the belts start squeaking for a few seconds then it's all normal again.
What's wrong with it? How to make it "shut-up"?
Thanks, guys.
Old Apr 27, 2005 | 11:11 AM
Pat2002SE's Avatar
I have the exact same thing happening. I was planning on replacing the belts during the summer. I only have 38k on the truck and had this happen before but with far more miles on my other truck.
Old Apr 27, 2005 | 11:14 AM
jimbo74's Avatar
dont get them wet... you must realize that the belts are rubber and rubber has oil in it... if its wet, they slip. just as tires spin when it rains.....
Old Apr 27, 2005 | 11:15 AM
lee's Avatar
lee
they probably need to be replaced.
what do you mean when you say 'engine wash'??
to silence them for now, you might want to try a can of belt dressing.
Old Apr 27, 2005 | 11:16 AM
Glenn's Avatar
You can try belt dressing, but I always had better luck with tightening them a touch when they squealed.
Old Apr 27, 2005 | 11:39 AM
YotaJunky's Avatar
It sounds like your belts are loose. If the belts still look good, tighten them up a little. Not too much otherwise you'll increase bearing wear in your alternator, power steering pump etc... If you've got more than the manufacturer's recommended miles on your belts, you're probably better off just replacing them.
primordialbeast117
Dec 19, 2015 12:23 PM
mbomberz1
Oct 9, 2015 07:17 PM
moparbay
Oct 6, 2015 09:24 AM
EVars
Sep 29, 2015 02:06 PM
gentry
Sep 28, 2015 06:16 AM
