Answer needed ASAP
Old Apr 4, 2005 | 11:41 AM
Poopy's Avatar
Answer needed ASAP
Where are the connections located that I need to connect a jumper wire so I can check the timing? I need to go to work so can someone post the answer in the next 5 minutes.
Old Apr 4, 2005 | 12:27 PM
BoulderG's Avatar
Hi -
On my 1989 pickup with the 22RE, it is E1 and Te1 , I THINK.
Although I did this yesterday, I am not 100 percent certain.
Didja try searching on the forum? I am sure this is posted somewhere.
I if you look at the diagnosis plug, it has a number of holes. From memory, I am doing the left side of the plug only and using X for no and O for where the jumper goes.
ENGINE
X X O X
X O X X
X X X X
FUSEBOX
FENDER
For your own good, I encourage you to confirm this!
Good luck.
bigjstang
Jun 2, 2025 03:56 PM
Road Bull
Oct 10, 2015 04:55 PM
colinmil
Jul 6, 2015 04:03 PM
mickyd9990
Jul 6, 2015 09:01 AM
karbin
Jul 5, 2015 11:37 PM
