98 runner stalling
Old Feb 12, 2004 | 09:26 AM
CUBERA's Avatar
98 runner stalling
looked up a search on this problem but found too many opinions, hopefully you fellas can help.
My 98 runner stalls occasionally with the a/c on mainly.
But with a/c off it does not stall.
My idle with air on is 600rpm.
Today while letting off my gas pedal at 25mph for 3 seconds it stalled but then quickly restarted.
Then while sitting idle in drive mode for 10minutes to pick up my daughter at school it stalled. This story has occured 3 times at her school.
My fuel filter was changed 9months ago, along with new timing belt and plugs at the dealer before purchase. I cleaned throttle body with "o" gasket mod. 3 months ago.
I'm wondering if the oil from amsoil filter is getting on maf sensor?
I'm mechanically inclined so i hope to fix myself.
Old Feb 12, 2004 | 01:21 PM
SLC Punk's Avatar
Could be your MAF or O2 sensor, it may be running it too rich to the point where it stalls.
Do you get a CEL?
Old Feb 12, 2004 | 03:32 PM
CUBERA's Avatar
There is no check engine light.
How do you replace the 02 sensor? Do i get oem or auto store?
Old Feb 13, 2004 | 11:50 AM
SLC Punk's Avatar
I have had problems with O2 sensors that I get at autostores, the wires are either too short or too long. And some are universal, where you splice the connector to it.
To replace an O2 sensor you get a O2 socket (pretty cheap) and a ratchet and screw it off. Its pretty easy to do. But they are expensive.
Charecter1
Nov 6, 2023 10:08 AM
icentropy
Sep 16, 2020 02:47 PM
MTLroadierunner
Jul 15, 2015 12:58 PM
Jnkml
Jul 6, 2015 01:20 PM
HRDC0R19
Jul 5, 2015 06:43 PM
