3.0 idle
3.0 idle
I couldnt sleep much lastnight so ofcourse i was on here reading stuff. I have always thought that my runner sounded rather loud at idle 1200rpms. I read that the manual asks for 800rpms. I took it down to 800 and it made hardly any noise at all. Since im still learning the 3.0, i took it to 1000. The engine seemed to sound good and kept a steady idle. Any input on whether i should go back to 800 or what? I figure it probably isnt good for the motor to idle 400rpms above stock. Right now Il stay in the middle of the 2.
Co-Founder/Administrator
I'd keep it at 800, that is where I have mine at and it idles good and doesn't shake at the RPM.
http://www.pnw4runners.net/tech/tune-up_info.jpg
http://www.pnw4runners.net/tech/idle_screw_V6.jpg
When I corrected my timing the idle went up to about 900. 940 according to the emissions computer during my last inspection. My idle is a lot smoother now but I'm sure that has more to do with the out of spec timing than the idle speed. I've noticed my truck does run better with the A/C on if the idle is higher so if you use the A/C a lot split the difference and shoot for 900.
I adjust mine to between 700 and 800 RPM so it looks like 750 once everything has warmed-up. Higher RPMs effect your emisons and economy (MPG) more than anything else.
Well talking to you guys made me decide to adjust mine. I picked up a can of throttle body cleaner and with an old toothbrush cleaned the throttle body out the best I could. A lot of carbon came out of the intake and throttle body. I especially noticed a lot of gunk was building up on the shaft where it goes through the throttle body.
After the cleaning my idle jumped from 900 to over 1250. I adjusted it down to 750 and now when I turn on the A/C the idle doesn't drop anymore. It works just like it should - and noticably smoother too. My truck is due again for its emissions check at the end of the month and I get a computer printout with the exact idle and emissions at idle. I hope to see an improvement from last years numbers.
ZONAYODA
Jul 13, 2015 07:17 PM
