Engine Swaps Swapping an engine in your Toy, here is where to learn how
Engine swap
Old Jan 10, 2017 | 05:24 AM
K9chooch's Avatar
Engine swap
can i put a 94 toyota engine and transmisson in a 86 toyota truck.
Old Jan 10, 2017 | 05:27 AM
dropzone's Avatar
Fossilized
sure but you may run into differences with plugs. and you might need the ECU from the 94
Old Jan 23, 2017 | 12:29 AM
wyoming9's Avatar
Red face
This is if both engines are the same !!
Going from a Auto to manual has some more issues
You will need every thing to the 94 engine .
All the electrical and ECU then your going to need to wire the fourth ECU plug
The main issue is the injectors they are different between those years
The other option is to strip the 94 engine down to the bare long block and install all the 86 electrical parts onto that engine
Both options are work just what ever is easier for you .
