Engine Swaps Swapping an engine in your Toy, here is where to learn how
3VZE??? Deal or “NO” Deal ???
Old Jun 15, 2008 | 09:44 AM
tyes's Avatar
Anyone every bought from http://www.toyotacarpart.com?? I’ve found a long block for a deal, $1500.00 for a 3VZE. Even called them and it seems legit. The long block comes with everything except VC, manifolds, cam gears, oil pan, etc…. everything internal is install and torque to specs…. All I need to do is add the external parts from my motor and set timing..(OR) Is it too good to be true…. Any thoughts on this deal…
Old Jun 15, 2008 | 09:54 AM
olharleyman's Avatar
Seems that by the time you redo the heads and cams(machine work and parts to rebuild) and everything else your going to be right in the $2500-$3000 range.
For that you can do the 3.4 (not that I am pushing it) but you can get so much more out of the 3.4 power and fuel mileage wise that it might be worth looking into.
Old Jun 15, 2008 | 04:44 PM
tyes's Avatar
I dont think this setup will cost that much. Since we are just going OEM with no mods..I've research into a 3.4 setup as well. But after research and research, I dont really want to deal with Cali Smog Regulations and so forth. I've deal with that so many times with Hondas / Acuras, I dont want to add Toyota to the list. Like I mention this long block comes complete with everything and all I need to install is just the basic exterior parts of the engine. This will cost me no more than 1500.00 + shipping + 200.00 (misc parts)... And, It will make room for a suspension lift, new pro-comp wheels, 35x12.5 tires, and 5.29 US Gears.. Thats why I'm more leaning on the 3.0 setup than the 3.4.. Thanks for the suggestion... I was actually going for the site I have listed. I've also seen in listed here on yota tech a few times. can anyone input???
moparbay
Mar 10, 2023 03:50 PM
RobotMoose
Feb 22, 2020 07:44 AM
Longbed 90
Mar 11, 2019 12:38 PM
LotOMiles
Sep 14, 2015 11:45 PM
