Camping, Expedition, & Overlanding Gear Discussion pertaining to outfitting yourself with gear for the great outdoors
Lets talk fire extinguishers
Old Sep 9, 2007 | 10:27 AM
Corey's Avatar
Co-Founder/Administrator
I am a little confused on the subject, and I really need a new one.
I have a small Kidde one and a chrome rechargeable one I bought around '91 from Northwest Offroad.
THey are both old, and do not have good mounts.
After doing some research, I found a few links.
Here is one that is more of an aerosol can, but it puts out fires good, but the can is rather large.
It is made by Pyrocom.
http://www.thefirestore.com/store/product.cfm?pID=3440
http://www.pyrocom-spray.com/
Good video
http://www.pyrocom-spray.com/video/pyrocom_dvd.mpg
Here is another one I am looking at, and member KD7 has one by h3performance, the HalGuard one.
http://www.h3rperformance.com/index.htm
HalGuard model
http://www.h3rperformance.com/halguard_products.htm
Wayne's model in red, the HG250
http://www.h3rperformance.com/hg250r.htm
Also available in chrome
http://www.h3rperformance.com/hg250c.htm
It looks like a good choice, now to find a place to order one from.
Anyone running this unit besides Wayne?
Clean agent extinguishers from H3R Performance.
These H3R Performance HalGuard fire extinguishers feature a clean agent--an electrically non-conducting liquid or gaseous fire-extinguishing agent that does not leave a residue.
They feature high-quality steel cylinders with all-metal valve construction, are available in chrome or red painted finishes, and are compact, lightweight, and easy to use.
The H3R Performance HalGuard fire extinguishers will leave no mess or damage to the vehicle or surfaces, will not impair the operator's vision, provide no thermal shock to electronics, and are EPA-approved.
The liquefied gas extinguishes those hard-to-reach fires common in many applications.
Clean agent fire extinguishers like these H3R Performance HalGuards have long been the product of choice for protecting classic automobiles and race cars, not to mention aircraft, computer rooms, and other high-tech equipment.
Old Sep 9, 2007 | 11:01 AM
KevinInSac's Avatar
I could have used that aeresol can when the alternator in my Grand Marquis caught on fire...
Subscribing: I need an extinguisher too.
Old Sep 9, 2007 | 11:07 AM
Corey's Avatar
I am leaning towards the one that Wayne has, will more than likely mail order it.
It is hard to find local shops that have this stuff.
Old Sep 10, 2007 | 09:49 AM
Corey's Avatar
Ordered the red HalGuard.
It should be here Friday.
May mount it then or wait until Saturday to mount it.
Pictures will follow the installation.
Old Sep 10, 2007 | 02:45 PM
KevinInSac's Avatar
I'm going to order one once I find a job. I aleady know where I want to mount it. Right between my rear seats vertically.
Old Sep 10, 2007 | 03:18 PM
Corey's Avatar
Cool, you will like it.
I know they are much more pricey than the dry chemical ones, but they are worth it.
I talked to a local fire extinguisher shop today near work, and he said they are the way to go.
They carry a different brand though, but the material is very similar.
The dry chemical ones (Kidde and others) can corrode stuff under your hood, and do not even attempt to use them on your home PC equipment or electronics in your vehicle.
You will ruin them.
* No thermal shock to electronics
* No mess or damage to vehicle or surfaces
* Liquefied gas extinguishes hard-to-reach fires
* Does not impair operator's vision
* EPA approved
* Listed and rated 2B:C by Underwriters Laboratories
* Rechargeable
* Made in U.S.A.
* 2-strap mounting bracket
* 6' - 10' discharge range
* High quality steel cylinders
* All metal valve construction
* Compact, lightweight, easy to use
* One year limited warranty
Old Sep 10, 2007 | 04:00 PM
KevinInSac's Avatar
So which size did you order? 100 or 250? I'm gonna go chrome, I think it'd be a little more appealing inside the cab.
Old Sep 10, 2007 | 07:19 PM
flyfishexpert's Avatar
Where did you order it from?
Old Sep 10, 2007 | 07:30 PM
drguitarum2005's Avatar
From: Houston (home), Atlanta (school), Cincinnati (work)
how much was it if you dont mind my asking?
Old Sep 10, 2007 | 09:51 PM
BajaTaco's Avatar
Corey, that looks like a very good choice. Three types of extinguishers can be useful for vehicles - dry powder type (ABC), halon (clean-agent), and foam (AFFF). The latter is for flammable liquid spills (such as fuel on the ground) so may be appropriate for larger specialized vehicles carrying large amounts of auxiliary fuel that may spill or for racing applications, but not as applicable to us. The powder is economical and depending on the type can put out fires from solids, fuels, and electrical but as you mentioned, it can be quite a mess. The clean-agent (Halon) type is a liquid stream that gasifies when it is deployed, and fights the fire by displacing oxygen. Therefore it will work best in confined areas such as inside a vehicle or in an engine bay. If you want the best of both worlds, carry a halon unit for application on your vehicle and a powder unit (ABC) for fires outside of your vehicle (camp site, public hazards, etc.)
HERE is an interesting article on vehicle fires from Off-Road.com
Old Sep 11, 2007 | 12:05 AM
Corey's Avatar
Keven, the 250 model.
Beau, they have a list of resellers on their website, I went with Jegs.
David, they go for $119 not counting shipping and hazmat shipping fees.
Thanks Chris for the information.
Will check out that link too.
Old Sep 11, 2007 | 12:27 AM
stormin94's Avatar
I just run a standard ABC Co2 gas extinguisher(I think it's Co2). I've never personally put my car out(or myself), but I have used it on small roadside fires. Two times I have seen smoking brush, or small flames on the side of the road, usually caused by the pricks who fail to use their ash tray for their cigarette butts. I've put both of the fires out, one was on a very hot windy day(106degrees, 30+mph) and not much other traffic, and more importantly, no fire stations anywhere close. I've also saved a drunk guy from burning himself severely, when he dropped his nice tool box into the fire. Let's just say the fire didn't stand a chance, but it was kind of a lost cause, because the guy didn't wait for the tools to cool down before he picked them up, and burned himself anyway, but not bad. That thing was a handy little brute, and I'll definitly buy another one once this one goes "up in smoke".
Old Sep 14, 2007 | 06:21 PM
Corey's Avatar
It is in.
I have a custom mount coming from Luke @ www.fourtreks.com , but I think I will stay with this setup here if the ARB fridge will clear it.
I will have to test it tomorrow if it clears the fridge or not.
I can also raise the mount up a few inches higher, but I may leave it in the low rider position.
It is bolted with 4 bolts right to the side of the Powertank bracket.
Old Sep 14, 2007 | 06:29 PM
bballchrism's Avatar
sweet man all the thing you install look so awsome and clean
Old Sep 15, 2007 | 10:06 AM
Corey's Avatar
Thanks man, it is a labor of love
My father was very meticulous in the tasks and work he performed, it rubbed off I guess.
I am very anal about the way I do things, and try to make something fit right so it does not look out of place to much.
I feel much better now having a fire extinguisher in the rig.
Did not have one before, but I carried two dry chemical ones in the old rig.
Never again will I carry a dry chemical one for using on the rig.
You are only going to ruin something on your rig when you use it.
I will probably carry the Kidde one though as Chris above mentioned they are good for outside of your rig when you do not need to worry about the dry chemical types fubaring up anything.
Old Sep 15, 2007 | 10:28 AM
waskillywabbit's Avatar
I got my fire extinguishers for both my shop and vehicles from the local fire supply place that services our extinguishers at work. MUCH cheaper than Lowe's, HD or online.
Old Sep 15, 2007 | 10:32 AM
KevinInSac's Avatar
Are the ones in your rig the "clean" type?
Old Sep 15, 2007 | 10:41 AM
There is nothing on my rig "clean" now, so why bother making a "clean" mess with a fire extinguiser if I have to use it.
Old Sep 15, 2007 | 10:55 AM
KevinInSac's Avatar
Haha, touche.
Old Sep 16, 2007 | 10:29 AM
Corey's Avatar
I added the Kidde dry chemical one a few minutes ago to the plastic lift off tray in the back.
Used a few stainless bolts and nuts, the same ones that held it onto my Husky floormats when they were in the 4Runner.
The Kidde will be used for outside fires not rig related since it is a dry chemical unit.
