Twistedyota's 87 SAS
Old 07-04-2011, 02:20 AM
nvtoyota's Avatar
looking good bud
Old 07-04-2011, 10:47 AM
twistedyota's Avatar
Originally Posted by nvtoyota
looking good bud
thanks
Old 07-04-2011, 10:54 AM
ChefYota4x4's Avatar
Twisted....... SICK DETAIL, MAN! I know where I'll be coming for a pic-by-pic tutorial if I ever do this!
Great work, and I wish you the best(no major hiccups! )
Old 07-06-2011, 08:49 PM
well my order for the knuckle service kit is confirmed today. was hoping to get it today or tomarrow, but i guess i can just hope to get it on sat.
got myself a job and will be working all this week and probably all next week except sunday. so im crunched on time. think ima lose my bet to have the swap done and it drivable by the 10. but i am still going to push to get as much done as possible. for the whole cutting it may be a bit now, because the the only time i would have access to a shop is on a weekend and the only time i can get help is on sat.
this may just mean it will get done better then i had first planned, might actually spend some more money on some stuff.
Old 07-08-2011, 06:35 PM
  #25
dont know if it was because i sent an email or just a coincidence, tht an hr or so ifter i sent an email asking when i should be expecting my parts. i recieve an email saying my order has gone from confirmed to shipped.
but anyways. it says i will recieve it on monday. guess i lost my bet, dang. owell
Old 07-12-2011, 04:54 PM
  #26
got my knuckle rebuild kit yesterday, and found the pic of what i started with when building my hanger. will post pictures of it later.
should hopefully have my axle fully together besides the steering this weekend.
still waiting on some bolts, and trying to find the differance between the front spring bushings and the rear spring bushings. anyone know?
Old 07-13-2011, 10:02 AM
  #27
petyamiller's Avatar
Great build, keep it up!
Old 07-17-2011, 07:15 PM
  #28
my cousin gave me some spring hanger bolts, so when i get a chance i can build my hanger. also i should be getting my steering figured out this weekend.
the only thing i dont know yet, and need to look around for is what type of grease people are using to fill the knuckles and how much.
Old 07-18-2011, 06:02 AM
  #29
84Horunner's Avatar
On the grease, i hear Moly Fortified. Others can chime in if i'm wrong...thats what i've heard.
Now how much grease...on your knuckles there should be a plug that is tapped, and you can take it off and fill it up. Just pack your birfields, install everything. Then take a grease gun and go to town. 1/2 tube should be good.
Old 07-18-2011, 06:08 AM
  #30
waskillywabbit's Avatar
Front leaf spring bushings are smaller in OD than rear leaf spring bushings.
Some pics on my website.
High temp wheel bearing grease is what I use. Last stuff was LUCAS I believe. It was a nice RED color and good and tacky.
:wabbit2:
Old 07-20-2011, 08:08 PM
  #31
:wabbit2:
thanks for the info
for springs my cousin is giving me a pair of international springs so i gotta do some figuring on al what im gonna do their.
and he also gave me some spring bolts so. when i get some time i can build my hanger finally
Old 07-22-2011, 10:35 PM
  #32
been busy with work and my daughter so i have done nothing. my cousin gave me the spring bolts but only 4 of them, and i need 6. but today a family friend tht works at a hardware store got me 2 grade 8 4in long 3/4in thick bolts tht will be used for the front of the springs through the spring hanger.
Old 08-12-2011, 11:18 PM
  #33
ok its been a little bit since ive updated, been busy with work and my daughter. so i told you all tht the original axle came from a wrecked truck and the top trunnion bearings were shot, i also showed a picture of a striped out knuckle and a bolt i had to cut.
well thts what im waiting on. im trying to get a heli-coil for tht one knuckle so the caliper will bolt on. once i get tht it will be rebuild time.
but im not sure if im going to do the swap anymore.
tht is because i just got 1/2 ton chevey axles from my cousin today, so i may end up doing full width instead. or maybe do one truck toyota axle and the other full width. we will see.
Old 08-13-2011, 10:07 AM
  #34
Wow, that's quite an update..... Hope the lil one is doing well!
Best wishes on the work, man!
Old 09-11-2011, 07:43 PM
  #35
nothing new yet. im kinda stuck on extra time to build the axle and tht the one knuckle has a striped caliper hole. so i have 2 choices
1. heli-coil it
2. get another knuckle
i cant find a correct heli-coil for a good price, napa auto parts only sells their whole kit and they want almost $100 for it. while i havent been able to find a knuckle for a decent price. well at least one tht i can afford after paying bills.
Old 09-11-2011, 07:45 PM
  #36
YES, THOSE FREAKIN BILLS! They shouldn't even have enough paper for that many bills!!!!!!!!!...... but sadly, they do hahaha.
You'll get it... Any chance you could ask Teuf if he's got a hook up on the thing you need? He's still up there, no?
Old 09-12-2011, 09:18 PM
  #37
i forgot he was near me but i dont think he would have a heli-coil or a knuckle.
Old 09-12-2011, 09:22 PM
  #38
Well, he has lots of tools/stuff, ....maybe he has the heli-coil or a line on one that would work? Worth a try, no?
Old 09-16-2011, 05:20 PM
  #39
mybe. but ive come to a descion. ima do it the cheap way and drill and tap it to probably a 13mm.
Old 09-16-2011, 09:20 PM
  #40
just bought the snap ring i needed to keep the inner axle shaft connected to the birf, also had some grease orderd for the axle. hopefully tomarrow i will retap tht knuckle hole.
also looking at getting high steer, but looking to get it in parts.
Quick Reply: Twistedyota's 87 SAS
