toyota drivin liberty
Old May 3, 2012 | 10:11 AM
saabota's Avatar
Originally Posted by 77camaroCIVICkiller
well thatll be bad ass man lookin forward to the build
thanks man
ill get some pictures added here of how it currently looks
Old May 3, 2012 | 10:13 AM
saabota's Avatar
Old May 3, 2012 | 12:17 PM
vital22re's Avatar
totally a bro
so are are you gonna weld plate onto the unibody then use that to weld mounts to? or just find a complete rolling frame and drop the liberty on top of it?. Have you thought about what you're gonna do about the gauges? Abs? A/C? shifter?
Old May 3, 2012 | 12:34 PM
saabota's Avatar
welding 1/4in plate to the uni body to attach everything else to keep cog down the gauges will all be done with either sr5 gen 2 stuff or auto meter custom. its going to be a trail rig. no abs no a/c and its going to be a manual already have a hydraulic pedal set for it
Old May 3, 2012 | 12:46 PM
  #25
vital22re's Avatar
totally a bro
will you build sub frame to hold the motor? If you want to keep it a 4cyl then i'd 3rz is the current transfercase a passenger side drop or driver side drop.
Old May 3, 2012 | 01:12 PM
  #26
saabota's Avatar
it already has a sub frame for the engine. and i have a 86 5 speed and two transfer cases. so it will be passenger side drop.
Old May 4, 2012 | 03:37 AM
  #27
vital22re's Avatar
totally a bro
Well you better start posting pictures of your progress so people can get an idea of whats going on.
Old May 4, 2012 | 05:59 AM
  #28
saabota's Avatar
project has not officially started yet i am gathering parts and making plans i was positing to see what everyone thinks of the idea.also to maybe get some ideas for the project. i think its going to be a fun build and i will start a build thread as soon as we start stripping down the jeep scrap metal parts. so ill keep everyone updated
Old May 4, 2012 | 06:27 AM
  #29
cblackard's Avatar
Originally Posted by saabota
i understand the 3.7 has more power but the jeep automatic trans is trashed the t case is worse. and the 3.7 is not that great of an engine it needs a bit of work. and i dont just want to put the body on the frame i want to build a ligit good crawler out of this rig and putting the body of a uni body jeep on top of a toy frame is way to high of cog. i have not decided entirely on the engine its just i have a 22r with a 5 speed trans and two t cases ready for it so even if it comes down to putting the 22r in for a short time to build the next engine then that's what ill do. there is no emissions in the county we are in. and im not looking to save my self work i want the challenge of the project and just to show a lot of people that you can do anything if you want
As long as this thing isn't going to be a mostly DD on highways, build it with the 22RE and give it some nice low gearing to get the ummmpph it needs.
What was the tire size that was going on this rig? I'd say with 36s or smaller, run 5.29:1 gears. That would help it along and the 22RE can surely take the extra RPMs with no issue.
Old May 4, 2012 | 06:50 AM
  #30
saabota's Avatar
we were gonna do dual cases stock in one and the 4.70s in the other the 5.29:1 locked front and rear possible high pinion with a 37 12.50 we will have to do a little body work to clear the 37 but with bump stops and lots of down travel it should be great it will on trailer with my gen 1 up to the trails most of the time for wheeling unless staying close by.
Old May 4, 2012 | 06:52 AM
  #31
Team420's Avatar
a 2001 Jeep Liberty 3.7l v-6, 4x4 weighs approximately 3600lbs, a 1986 toyota 4runner 22re weighs a lil over 3500lbs. I would venture to say the 3.7 weighs almost double what the 22re does, so by putting the 22re in that liberty you will actually be lowering the weight. While the liberty was def more "peppy" than the 86 runner, those runners made perfectly adequate trail rigs (more so than a liberty w 3.7l IMHO). So... I wouldnt think the weight thing should be an issue, especially with dual cases.... I'm sure it wont have as much gitty up and go as the 3.7 did, but will prolly have more than the 86 runners did.... and still be just fine offroad!
That being said... If it were my project (which it is not!) I would look at swapping a 4.0l 6cyl from a cherokee or wrangler.... but thats just me... I'm interested to see how this swap turns out, Good luck to ya!
Old May 4, 2012 | 07:53 AM
  #32
saabota's Avatar
the thought of doing the 4.0l was a consideration but its a much longer engine than the 22re and would limit us on space for the items like on board air with a york compressor. and we would have to adapt it to the Toyota trans. so we decided against it and are going to keep it Toyota engine and trans. im not really worried about the weight thing the 3.7 v6 is a heavy engine for sure plus we will lose weight in the ac system
Old May 5, 2012 | 03:13 PM
  #33
pyrojoe22's Avatar
I personally hate liberties cus all the sorority girls drive them and they look feminine, but I like the idea of custom stuff. I just put a mercedes diesel in my toyota pickup. It sure turns heads. Just be prepared for a loooooot more work than you expect. If you make good designs and plans and follow thru, you will be extremely satisfied once you are done. I also don't like the idea of the unibody, though. A wrangler would be a lot cooler (that's just my opinion, though).
Old May 5, 2012 | 04:17 PM
  #34
Team420's Avatar
Gotta ask... How's the fuel economy? I been considering doing the same, or an isuzu diesel from a box truck... not so much for offroad use (although, it will pull logs a lot better w a diesel) Mostly just looking to improve my mileage. 12 MPG is just not gonna cut it at almost $4/gal....
Old May 18, 2012 | 04:18 PM
  #35
Dras16's Avatar
I have a liberty and a 4runner. My 4runner is my crawler and the liberty my daily driver. I have always wanted to lift the liberty but would rather spend the money on my yota. I think it will be pretty cool when its done. Make sure you post pics as you go!
Old May 21, 2012 | 02:33 PM
  #36
pyrojoe22's Avatar
I'll know a lot better with bigger tires and lower rpm's in 3 weeks, but for now here's my numbers.
22R 14 in town
16 highway
OM617 22 in town
20 highway
Old May 24, 2012 | 05:54 AM
  #37
saabota's Avatar
I Will be starting a build thread ass soon as we get under way here for now we are still part collecting.... its gonna be a sweet day when we set the liberty on its new guts and see it leaf sprung and ready to go.
alot of people have told me dont go leaf do link......well if we were going to do link we would just put a jeep axle under the front and put 5 in springs in the rear... we dont like this idea we want to do toyota everything
it will be the libota
Old Jul 19, 2012 | 07:05 AM
  #38
rattlewagon's Avatar
Bump?
Colington
Mar 8, 2020 09:51 AM
Sep 4, 2015 09:27 AM
crashburnoveride
Aug 28, 2015 09:20 PM
nick b
Jul 11, 2015 04:38 AM
