pitman arm option
pitman arm option
i bought a used hi steer kit and it didnt come with a pitman arm. and i was stupid and over looked that the stock ifs one wont work for it
. so i was wondering if there is a straight replacement that i could pick up from the auto store/ maybe junkyard or do i have to buy one for a hi steer. also if that is the case has anyone just drilled/press out the tie rod thing and just used the old pitman arm for a temporary solution.
No other application pitman arm that I know of, you pretty much have to use the high steer pitman arm, or you could possibly use the adapter that SORD makes.
http://www.sky-manufacturing.com/cgi...ey=TOY-PAA-001
I have one, and a flat pitman arm in case I need it, but haven't done my sas yet so I can't give you a real world review yet, sorry.
ok i was looking around on ebay and found a fj40 pitman arm and was wonderin if it will work. it looks the same as the trail gear arm with holes on both ends but I am wondering is there a difference the the steering box shaft.
I believe the Sky's Off Road Design pitman arm adapter is only around $30.00. Google sky manufacturing. It will thread into your drag link and has the correct taper for your pitman arm. I have ran one before with no problems. They have some top notch stuff.
