new to solid axle
Old Jun 29, 2007 | 09:23 PM
weakyota91's Avatar
new to solid axle
Im doing a s.a.s and had a few more questions. If i go with the 6 inch lift springs will the v.6 oil pan still be as much of and issue with steering as if i were to go with the 3 or 4 inch springs. It seems the higher you go with the suspention of the truck it would get farther away from the draglink. correct me if im wrong? Thanks.
Old Jun 30, 2007 | 06:00 AM
waskillywabbit's Avatar
A SAS is not a "bolt in" lift kit, it does require some fabrication and welding and placement of items such as your bumpstops, steering box and axle will determine whether or not you have any "issues", but normally you should not hit the oil pan if installed properly.
Old Aug 3, 2007 | 11:45 PM
mqhoon's Avatar
mines a 5" trailgear in a v6, works fine, sagged after 4 weeks to a 4" now.
80Truck
Sep 15, 2015 04:21 PM
89hilux1
Sep 14, 2015 06:13 PM
reallynotamechanic
Sep 11, 2015 11:52 AM
theduck21
Sep 10, 2015 07:01 PM
