need help!
Old Apr 16, 2013 | 08:41 AM
tms89yota's Avatar
need help!
I've been looking on threads and can't figure out if I use the trail gear highsteer kit do I use my original Pitman arm on my 89' or what do I need if not?
How do I set the preload on the wheel bearings?
Old Apr 16, 2013 | 01:39 PM
JonnyBoy's Avatar
No, the Trail-Gear high steer kit, and all of them that I can think of, use FJ80 rod ends at all ends of the steering links, so you'll need a pitman arm that has a hole in the end rather than the stud that is on your stock pitman arm.
For the wheel bearings, there's a bit of a complex way to do it. I don't know it off the top of my head, but if you search for "wheel bearing preload setting" in the pre 84, 84-85, or 86-95 Pickup/4Runner sections and someone has posted it, step by step.
Old Apr 16, 2013 | 02:24 PM
tms89yota's Avatar
Ok so do you know if trail gear carrys that pitman arm?
Old Apr 16, 2013 | 11:45 PM
JonnyBoy's Avatar
Yes. They have a version with the same amount of drop as stock or they also have a flat version so people can go with whatever works or is their preference for relocating the steering box.
Old Apr 17, 2013 | 02:36 AM
tms89yota's Avatar
Oh ok thanks for the help!
Old Apr 17, 2013 | 08:59 AM
4Crawler's Avatar
Wheel bearing pre-load techniques:
- http://www.4crawler.com/4x4/CheapTri....shtml#Rebuild
Old Apr 17, 2013 | 09:03 AM
tms89yota's Avatar
Thanks for all the help can't wait to post pics of it when its all finished!
