My '94 4Runner SAS
Old Nov 26, 2007 | 09:30 PM
Blizzard's Avatar
I'm from Barcelona, this is the north-east of Spain. Just the opposite side hehe
You've Morocco near then.
David
Old Nov 27, 2007 | 06:41 AM
AxleIke's Avatar
David, you gotta get er done, and go out and get some wheeling pictures!!!!
Old Nov 27, 2007 | 07:33 AM
isaac338's Avatar
dude.. simply stunning work.
Old Nov 27, 2007 | 08:21 AM
Blizzard's Avatar
Don't worry AxelIke, noone is more anxious to test it than me...
But I cannot drive it untill it's legalized...
David
Old Nov 27, 2007 | 09:05 PM
  #25
NC-B17A's Avatar
Very detailed post makes me want to sas my 92 4runner
Old Nov 27, 2007 | 09:12 PM
  #26
Marc P's Avatar
Looks great David.....with all the planning time you have had, how could it not be sweet!!
Old Nov 27, 2007 | 10:19 PM
  #27
Blizzard's Avatar
Hehe thanks Marc.
NC-B17A, don't waste your money on IFS if you've a little hope in someday doing a SAS... You'll regret as I do now!
If I ever knew that a SAS was possible in Spain I'd have been wheeling my truck stock + M/T tires and later SAS it... Hehehe
David
Old Nov 29, 2007 | 09:48 AM
  #28
Blizzard's Avatar
New pics from yesterday
Rear caliper brackets are finished and the calipers are mounted
The T-Case brake disc is in place:
Nothing more at the moment. We're working in the new exhaust line, rear brake lines and the crossmember that supports both fuel tanks.
David
Old Dec 4, 2007 | 08:16 AM
  #29
yotasavg's Avatar
great swap david!
Old Dec 4, 2007 | 07:11 PM
  #30
agusgus3's Avatar
great job on the build and the pics.
Old Dec 4, 2007 | 09:40 PM
  #31
Blizzard's Avatar
I've new pics of the exhaust and brake lines. I'll try to upload them later.
David
Old Dec 5, 2007 | 10:20 AM
  #32
Blizzard's Avatar
New pics.
This is the crossmember we're making for holding the dual fuel tanks and the UHMW PE skids we'll make for them and the T-Case.
This is the first section of the new exhaust, this bolts to the manifold out of the turbo.
Exhaust must have a flexible section, specially on a diesel. It's lightly smaller than the tube so we made a bit of modification so the gases flow isn't very affected.
First section tacked
Welding the pipe to the flexo
It gets hot hehe
Closed cuts
Angle grinding the welds
Nice! It's all 316 SS, 70mm ID with constant-radious bends
Here in place
We're going to mantain the LSPV as it's good to have for the legalization project and we're modding it to work with the new rear axle flex
New front brakes had sections
We welded a little braket for holding the brake lines in place
And the rear brake lines
Still unfinished
Maybe I'll have more pics in some hours.
David
Old Dec 5, 2007 | 11:50 AM
  #33
Swissdrums's Avatar
So clean. So perfect. Keep it up!
Old Dec 6, 2007 | 02:32 AM
  #34
Blizzard's Avatar
I've new pics hehe
Look what nice flanges for the exhaust my friends did.
The front is ready and painted
The shocks have to be 5150's but TG send those. I'll be receiving the 5150's soon
Steering damper is put too
I like the rear shock angle. Maybe we'll have to move a bit up the upper shock brackets
There are no bump stops as I want to put airbags in the rear
This is the dual shock bracket
This is the intake manifold. New and old one. One of the old manifold's "ears" broke when we were unbolting it to gain access to the injection pump.
I've also bought a Momo Champion steering wheel. In Spain you can put an up to 10% smaller than stock steering wheel without having to legalizate it. From 10 to 15% you must legalize it, so I'm adding this to my engineer project.
Today is non working day here but my friends are working in the truck. They hope to start today the engine and get the thing moving tomorrow.
David
Old Dec 6, 2007 | 08:02 AM
  #35
The Lovely Boyo's Avatar
More awesome work - I am jealous as hell!
The way you've mounted the rear shock brackets - won't that put a lot of stress on the joint at full flex? Would there be less stress if the shock ends were rotated 90deg?
But then again, you have the nice truck, mines almost stock - way to go David!
Old Dec 6, 2007 | 11:12 AM
  #36
Blizzard's Avatar
I don't think so... The axle travels backwards when flexing due to the shackle... It's true that it also rotates over itself, but less, and that's why the shocks have bushings hehe
David
Old Dec 8, 2007 | 08:32 PM
  #37
byron4's Avatar
great work.
Old Dec 9, 2007 | 10:20 AM
  #38
JordiGPS's Avatar
Amazing planning & performance...
- What's left?
- Expected (desired? ) date of 1st ride?
Congratulations !
Old Dec 9, 2007 | 10:46 AM
  #39
Blizzard's Avatar
Hahahaha hi Jordi
Tomorrow we expect to test-run the truck. Then we've to redo the front bumper brackets, design the rear bumper with tire carrier, mount the intercooler and make the fender flares... I think it's almost all...
David
Old Dec 10, 2007 | 06:50 PM
  #40
EvLTwiN's Avatar
Amazing write up.....the best i have seen on this site, as far as the rig, i dont feel the need to say anything. its already been said, wow. congradulations on the dream come true, maybe one day ill do it to, stateside. this is one post i will be sure to stay tuned in to.
