front axle
Old Nov 1, 2008 | 03:55 AM
fireman1559's Avatar
front axle
i hav searched but i couldnt find anything on the old 80 model suburban front axle i found one in a scrap yard and i was wanting to know if it would work what do yall think
Old Nov 1, 2008 | 03:58 AM
Toy-SkiTzo's Avatar
is it a k20 or k30 burb?
Old Nov 1, 2008 | 04:04 AM
not sure half of the body was gone which one should i b looking for cause yota axles r very few and far between round here so chevy axles r very easy to come by
Old Nov 1, 2008 | 04:16 AM
Toy-SkiTzo's Avatar
well either way the front end out of any suburban will be really wide weather it is a 3/4 ton k20 or a one ton k30 you will not be stret legal. unless you plan on building a dedicated trail rig get a toy axle,
Old Nov 2, 2008 | 08:21 AM
934rnr's Avatar
I wouldn't a d44 is much weaker than a toyota axle.
I would check www.craigslist.com in your area. Find a 85 and older toyota someone is selling as a parts vehicle.
Old Nov 2, 2008 | 06:14 PM
bigarms23's Avatar
it should work is it a 10bolt or d44 you might need to shorten it or run wheel spacers in the rear
Old Nov 2, 2008 | 06:45 PM
waskillywabbit's Avatar
Toy SFA axles are easy to find...and would suit you better.
Old Nov 3, 2008 | 06:19 AM
well it was hard but i found a land cruiser axle that i am going to use
Old Nov 3, 2008 | 10:54 AM
RevNL's Avatar
You've already found another solution, but...
It could be a good axle. It's probably a Dana 44 and might have flat top knuckles for a high-steer. Should be spring-over-axle. Wheel bolt pattern will match the rear Toyota axle. It's way too wide, of course, but it's not really that hard to narrow one. There are how-to's all over the web about how to narrow an axle.
FYI: Scout axles are a really bad idea for a swap. Axle tubes are smaller diameter than any other Dana 44, diff housing is cast for spring-under-axle, knuckles aren't flat-top, low steer arms are too long for the Toyota IFS steering box, caster angle is zero degrees. It's easier and cheaper to buy a Chevy axle and narrow it (or stick with Toyota...).
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
Cabell
Jul 24, 2015 12:14 PM
