Differential swap
Old Dec 4, 2019 | 09:29 AM
Crisd1810's Avatar
Differential swap
Hey guy I have an 89 Toyota pickup 4x4. Rear diff has gone bad and I’m looking to replace with a used one. But I can’t find a G252 only G254. Hear ratio is the same 4.56 both 8’ diameter but the G252 has 2 pinions and the G254 has 4 pinions. Is it safe for me to use a G254? Will it affect it in any way?
Old Dec 4, 2019 | 12:32 PM
millball's Avatar
If the gear ratios are the same, a 4 pinion 3rd can be interchanged for a 2 pinion 3rd member with no issues.
A little more heavy duty internals, is all.
Old Dec 4, 2019 | 03:27 PM
Crisd1810's Avatar
Ok thank and it would be the same if I want to swap a 2 for a 4 right?
Old Dec 4, 2019 | 03:37 PM
millball's Avatar
Yes, interchangeable either way. 4 pinion carriers were supplied with 6 cylinder equipped machines; while 4 cylinder machines were built with 2 pinion diff carriers.
All axle spline counts and flange patterns otherwise identical on the 8" 3rd members .Whether 2, or 4 pinion types.
Old Dec 5, 2019 | 03:08 PM
dropzone's Avatar
Fossilized
isn't the correct term spider gears? 4 for turbo & V-6 thirds and 2 for 4 cylinder diffs
the Pinion is what drives the ring gear...
Old Dec 5, 2019 | 03:15 PM
millball's Avatar
The differential carrier contains a side gear on each axle inner end, and either two, or four, differential pinion gears.
I think that this is good nomenclature. 'Spider gears is a term also used for the same parts.
The drive gear is also refered to as a pinion, as well.
Rjv_38
Apr 11, 2017 08:22 PM
DanStew
Mar 19, 2010 05:33 PM
the_ocho
Nov 29, 2009 12:05 AM
t_boneshacone
Apr 13, 2009 01:28 PM
slider_buck
Jan 26, 2005 08:25 AM
