Addicted Offroad Tacoma SAS
Old Jan 26, 2011 | 06:05 PM
ScottyC's Avatar
Just prepping the install for now. I'll update as we work through the install on it.
Not sure if anyone else has started one with TG's kit yet or not, so we may be the first.
Specs:
98' 2.7L xtra cab Tacoma swap.
Front TG Rock Assault axle housing
TG Tacoma SAS Kit "A"
Rear kit.
We'll be using 4" F&R springs to clear 37x12.5x17 KM2s.
We're sticking with a single, stock case for now as well. HP front 3rd with Yukon Zip locker and 5.29s. Rear 8.4 with ARB and 5.29s.
Old Jan 26, 2011 | 06:06 PM
ScottyC's Avatar
Some progress pics
ScottyC's Avatar
Old Jan 26, 2011 | 06:10 PM
dropzone's Avatar
Fossilized
can you post a pic of the front shackle mounts?
mainly out of curiousity but it looks like it is inboarded...
Old Jan 26, 2011 | 06:26 PM
87hillbillyoter's Avatar
lookin good scott!
Old Jan 26, 2011 | 06:37 PM
ScottyC's Avatar
Yes, they are frenched and inboarded. The mounting width is 29".
Scotty
Old Feb 1, 2011 | 02:17 PM
ScottyC's Avatar
Progress.
Old Feb 1, 2011 | 03:10 PM
JakeBhs09's Avatar
Scott will the taco sas kit fit on a 99 runner? They have the same frame correct?
Old Feb 1, 2011 | 03:52 PM
RMA's Avatar
RMA
Scotty
whats the benefit to doing this ? Honestly dont even know what this is but curios none the less.
Old Feb 1, 2011 | 04:04 PM
ScottyC's Avatar
Yes, it will. However, provisions need to be made for the speedo since most 4runners take the speed signal from the ABS system on each axle shaft.
Old Feb 1, 2011 | 04:05 PM
ScottyC's Avatar
Its helps keep the ride height down by frenching the shackle hangers into the frame.
Old Feb 9, 2011 | 06:36 PM
ScottyC's Avatar
So we knocked out the fabwork on the rear today. Frame is boxed and plated. Pinion angle set and axle hung. I still need to build the rear 5.29s 3rd with ARB. But, shackle angles in the rear are good and we flex through it today. Hoping to have it out of the shop and driving next week.
Old Feb 9, 2011 | 08:09 PM
malteserunner's Avatar
Looks good! I bet you're lovin' that new lift...
Old Feb 9, 2011 | 08:10 PM
ScottyC's Avatar
It just makes it sooooo much easier to work on stuff like this.
Old Feb 9, 2011 | 08:52 PM
dropzone's Avatar
Fossilized
Cool...been so long since i owned a Tacoma that I forgot they moved the LSPV to the other side
Old Feb 10, 2011 | 11:25 PM
tacoma_hopeful's Avatar
I am contemplating buying a tacoma and doing a sas swap. I was wondering if you could pm me how much something like this would cost.
Old Feb 11, 2011 | 04:54 AM
blake.nemitz's Avatar
scotty as always beautiful work man i like sas'd taco.
Old Feb 11, 2011 | 09:57 AM
ScottyC's Avatar
Call me at the shop. There are way too many variables to go over in a PM.
970-420-4198
Old Feb 12, 2011 | 12:34 PM
Sounds good, I will give you a call during the week
Old Feb 19, 2011 | 06:12 PM
from_CO_2_AK's Avatar
did you have to trim the fenders or wheel wells at all to fit 37s
my sas kit gets hear tuesday and were tearing in to her just wondered if ill have to trim it with the three inch kit and 35s
