1 ton full floater rear swap
Old Feb 12, 2015 | 01:24 PM
Kayakthecoast's Avatar
I have an 87 Sunrader 4x4with a 4.10 geared full floating 1 ton axle. Front is also 4.10 geared
I have found a brand new rear full floating axle but it's 3.9 geared.
Can I run a new rear full floater with 3.9 geared with a front geared at 4.10?
I know they are close, and I have a 4x4? Any issues or do they both need to be exactly geared?
How do I tell the axel I'm buying is a 3.9. I counted the fins on the outside it has 4 on each side, same as mine.
Old Feb 12, 2015 | 01:50 PM
millball's Avatar
The gears must be exactly the same ratio, or expensive trouble will ensue if you attempt to use 4wd..
No reason you could'nt regear your old front to 3.90 I guess, but I'm thinkin that 4.10s' are none too low for your large truck, as is.
Whats wrong with your current axle???
Old Feb 12, 2015 | 02:56 PM
Nothing wrong with it. I just came across a cheap brand new full floater. Thought I'd swap it out, and resell my 28 year old one! And have a few hundred bucks in my pocket.
How can I tell what gear ratio the new axle is? It's stamped 399?
Old Feb 13, 2015 | 11:30 AM
Anyone know what the axle stamp 399 is? It's on the new axle. Would like to know the pinion gearing before I pay cash for it.
My old axle is stamped 3Y8
Or how can I tell what gearing is the axle by looking at it?
Jun 1, 2021 01:51 PM
mskalmus
May 28, 2017 07:51 AM
coryc85
Sep 9, 2015 06:24 AM
MTLroadierunner
Jul 6, 2015 12:17 PM
toyoda8488
Jul 5, 2015 10:18 PM
