Off Road Trip Planning, Expeditions, Trips, & Events Discussion pertaining to scheduling trail runs and outings
The back forty @ Tahuya
Old Jan 1, 2004 | 07:39 PM
GRNTACO's Avatar
I was bored today so a friend, my girlfriend and I decided to head out to Tahuya to see what kind of trouble we could find. We found that there was a little snow on the ground, maybe two inches in the openings, but not enough to cause trouble. We also found the back forty and it is tight. There were a total of two rigs and it took about 1.5 hours from the time we hit the back forty trail head until the time we were back on the road. There was some technical stuff that required the use of the lockers, mostly to prevent damage. I found myself up against a tree twice, once I was caught between a tree and a rock, luckily when I got out to see the damage the door closing caused the dent to pop out. The only bypass on that trail was where they placed the three rock gardens, too big for me. Depending on which way you travel the rock gardens are at the very beginning or very end.
Out of a possible 5 on the fun factor I will give it a strong 4.2. On the the technical scale I would say a 3 to 3.5 due to the snow and tight, tight tree laden trail.
EDIT - The 3.5 is on my scale of technical difficulty. Not sure how the true scale works or what is involved to rate a trail.
Old Jan 1, 2004 | 07:55 PM
WATRD's Avatar
Oh how I am looking forward to those rock gardens
That Back 40 trail was where Lawnjob snapped his CV on the last chapter run out that way.
For a popular trail rating system, see http://www.wattora.com/ldord.htm I would say that trail is a 3.3 or so...
Old Jan 1, 2004 | 09:12 PM
smr4runner's Avatar
Hey Ben,
Thanks for the scoutting report.
Can't wait to check it out again.
Hope you all had a great x-mas and new year.
Mike
Old Jan 2, 2004 | 05:19 PM
tahuya January 1st
Very cool in the backforty!! Very tight and some cool tight, off camber, turns with tree hugging closeness. Ouch!! Nice job on the 2wd high gear, two spin away from the tree's Ben! Had a great time.
The water crossings were farily low - but plenty of them. Everyone going will should have a great time. The hill climbs are definitely getting there share of tire holes. Riff raff is deeper, and the back forty provides the begging of another Riffraft trail section.
See you on the 10th!
Patrick
Old Jan 5, 2004 | 08:15 PM
Mad Chemist's Avatar
Hmmm....sounds like some of the open-diffed rigs are going to have some problems with that trail.
Old Jan 5, 2004 | 08:26 PM
GRNTACO's Avatar
There could be. I think the trail will be harder going the reverse direction, we'll see on the 10th
Old Jan 5, 2004 | 08:31 PM
WATRD's Avatar
We took a couple of virtually stock, unlocked rigs through there and they needed the strap in a few places, but otherwise they did fine
Old Jan 5, 2004 | 08:35 PM
GRNTACO's Avatar
Hey Rob,
Is that monster going to fit on that trail. hehehe
Old Jan 5, 2004 | 08:48 PM
WATRD's Avatar
We shall see Of course, my definition of "trail" has changed a bit recently... hehehehhe
Old Jan 5, 2004 | 09:11 PM
Shane's Avatar
Hey Rob,
Is that monster going to fit on that road. hehehe
Old Jan 5, 2004 | 09:18 PM
WATRD's Avatar
heheheheh Now THAT is another story... It sure seems to make the drivers of small cars nervous...
Old Jan 5, 2004 | 09:21 PM
Shane's Avatar
Actually by road I meant that path the others call a "trail"
Old Jan 5, 2004 | 09:23 PM
WATRD's Avatar
hehehehhe
Are you going to come play in the rocks with me Saturday?
Old Jan 5, 2004 | 09:58 PM
Shane's Avatar
God I'd love to get out wheeling... Unfortunately I'm still having shock hoop issues, not much happier with how the AllPro hoops are fitting. They're better than the first set but still not right for my shocks, they need a little bit more height and the tabs are welded on at the wrong f'ing angle for external res shocks.
The quest continues, for someone with a tube bender and a new heater cause mine broke and it's frickin' cold in my garage without it. I've thought about picking up a manual bender and 1.5" die set since I'm going to want one soon anyways to build a cage, but I really wanted to do a hydro setup. Decisions, decisions...
Old Jan 5, 2004 | 10:17 PM
WATRD's Avatar
Bummer
The hoops are a pain to set up, but you will like them once they are set up. I get a lot of comments on mine.
Old Jan 6, 2004 | 06:13 AM
Shane,
Jeff Kelson at Badlands might hook you up, or even Crash on S.N.O.R.T- I've heard he's got some new toys and is getting into the fab business.
thefishguy77
Jul 30, 2015 10:59 AM
Poncho0206
Jul 10, 2015 06:21 PM
87blyota
Jul 10, 2015 04:31 AM
Kluch8651
Jul 9, 2015 10:39 AM
elwood73
Jul 5, 2015 07:07 AM
