Whats a 89 22re motor worth
First off it needs a rebuild. I did a head gasket and got false torque reading on the head bolts. Lost compression had it towed home and did a long block swap. When I did my mother swap the parts truck was the 89. So before I sold the 89 I pulled all the motor components I could. Efi starter wiring harness from engine compartment and ecu. Grabbed the coil radiator expansion tank,afm, air box and intake tube, alternator, stock exhaust manifold, and other miscellaneous parts. The block and head had 190 k when I did the swap.
What do you think it's worth
I would say that if the block and head are not cracked, and the crank and bores are still standard, it would be worth somewhere between $150-$350 depending on where you live.
I'd like to have a good core to build.
I see them on Craigs list with asking prices all over the place, but you can never be sure what you're really getting.
Once in awhile I see some rebuilder in Phoenix offering long block rebuilds for $595 exchange, but they must be loaded with Chinese slave labor parts.
MMA_Alex
25
Apr 18, 2017 05:07 AM
Sep 4, 2015 09:27 AM
WTB[PacSoWest]: Looking for a electric locking differential motor/ actuator
AaronM
Jul 8, 2015 07:15 PM
