85 excab efi 4wd what's it worth?
Brand new rebuilt engine bored .30 over
Brand new ENGBLDR Street head w/ Oversized Stainless valves and 270 H.O. Cam
LC Engineering Ceramic coated header
LC Engineering adjustable cam gear injectors rebuilt by witchhunter
Brand new 5.71 gears with Aussie lockers Front & Rear
High Steer Steering kit
Rear disc brake conversion
IFS Hub swap & IFS rear axle 1.5" extra width
Battery/Intake swap
35x10.50 Super Swamper Boggers
14" Bilstein Shocks
Low Range Offroad Rear shock bar
Trail Gear 14" front shock hoops
Homemade front bumper w/ Warn xd9000i
Bucket seats from a 95 4runner (better side bolsters and adjustable lumbar)
I added power windows, not factory but used factory switches
A set of half doors will also go with the truck.
I have the tailgate and the tire gate. Both will go with the truck.
The
The bad that I can think of:
-The steering box leaks, I have the rebuild kit to go with the truck though.
-The blend switch broke behind the dash. I just manually worked it under the hood.
-The winch needs a solenoid to work
-The truck does have some rust in the body line of the bed, on the drivers door, and on the front drivers fender where I hit a deer but straightened the fender back out.
What do you guys think it's worth?
junder28
25
Jun 21, 2016 06:24 PM
hjalti_gto
Aug 24, 2015 11:46 AM
