Links to FAQ's and Info!
Updated 4/15/09
Well I got tired of looking through several threads to find the thread I wanted, so I started a list of links to FAQ's and info about various things... Since its all nicely compiled I figured I'd share it. Hope this helps some of ya!
I'll keep adding to it, if I find more, and if theres some things that some of you know about, post them and I'll add them in!
General 4Runner/Pickup FAQ's:
.......... http://www.pirate4x4.com/forum/showthread.php?t=459180
.......... https://www.yotatech.com/~corey/tech/techpage.htm
.......... https://www.yotatech.com/~corey/4runner_faq.htm
.......... https://www.yotatech.com/forums/f120/toyota-faq-66255/
General FZJ80 FAQ's:
.......... http://www.sleeoffroad.com/technical/technical.htm
Online FSMs
.......... http://www.ncttora.com/fsm/
.......... http://www.4x4wire.com/forums/showfl...&Number=752426
AXLES:
Comparisons: http://www.pirate4x4.com/tech/bible/index.html
.......... http://home.4x4wire.com/erik/diffs
TOYOTA 8": http://www.4crawler.com/4x4/CheapTri...ch/index.shtml
.......... Rebuilding Info: http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
.......... .......... http://www.4x4wire.com/toyota/mainte..._end/teardown/
.......... .......... http://www.4x4wire.com/toyota/mainte...nd/solid_axle/
.......... .......... http://www.4crawler.com/4x4/CheapTri...eRebuild.shtml
.......... .......... http://www.4x4wire.com/toyota/tech/gear_setup/
.......... .......... http://www.pirate4x4.com/forum/showthread.php?t=281879
Toyota Component Strengths (D44/D60 too): http://www.pirate4x4.com/forum/showthread.php?t=350905
D44's: http://www.4x4wire.com/forums/showfl...b=5&o=&fpart=1.
D60's: http://www.pirate4x4.com/tech/billav...ont/index.html
D70's: http://www.pirate4x4.com/tech/billavista/D70/D70.htm
14 bolt: http://www.pirate4x4.com/tech/billav...ble/index.html
Hybrids: http://www.pirate4x4.com/tech/billav...HybridAxle.htm
Rockwells: http://www.pirate4x4.com/forum/showthread.php?t=313836
.......... http://www.jpmagazine.com/techarticl...ton/index.html
.......... http://www.fourwheeler.com/techarticles/77419/
Lockers:
.......... Toyota 8" Air: http://www.4x4wire.com/toyota/tech/arb_locker/
.......... Toyota IFS Air: http://www.4x4wire.com/toyota/4Runne...ifs_airlocker/
Stock Toyota Engine Improvements and Info:
20R/22R: http://ttora.com/forum/showthread.php?t=84715
22R to 22RE Conversion: http://pirate4x4.com/forum/showthread.php?t=316661
22RE: http://www.4x4wire.com/forums/showfl...=&fpart=1&vc=1
22RE Superchargers: http://www.toyotacatalog.net/M1WebGe...F-E6DF0C03E232
Engine Swaps into Pickup/4Runners:
General: http://www.mindspring.com/~jayk3/toyota/swaps.htm
.......... http://www.pirate4x4.com/forum/showt...hreadid=175795
Buick 231: http://www.off-road.com/toyota/buick_v6_swap.html
Chevy 4.3: http://www.off-road.com/toyota/tech/other/v6swap.html
Chevy 350:
Ford 302/351: https://www.yotatech.com/forums/f88/ford-302-351-swap-info-72065/
.......... http://www.whiteknucklemotorsports.n...d=38&Itemid=27
Toyota 3.4 V6: https://www.yotatech.com/forums/f160/3-4-swap-started-82145/
.......... https://www.yotatech.com/forums/f116/3-0-3-4-engine-swap-questions-81553/
.......... http://board.marlincrawler.com/index...&topic=19684.0
.......... http://www.andrewzook.com/content/view/22/37/
Toyota 22R to 22RE: https://www.yotatech.com/forums/f115...e-swap-129693/
Toyota 5M/7M: http://www.4x4wire.com/toyota/tech/supra/
.......... http://4x4.4t.com/4runner/7mswap.htm
.......... http://www.off-road.com/toyota/tech/supraswap/
.......... http://www.supracharged.com/forum/viewtopic.php?t=298
Toyota V8: https://www.yotatech.com/forums/f161/1uzfe-swap-into-2nd-gen-4runner-54771/
Toyota Diesel (1KZ-TE): https://www.yotatech.com/forums/f116/diesel-conversion-underway-77103/
Engine Swaps into FZJ80s
Transfer Cases:
Double Toy Cases: http://www.fourwheeler.com/techartic...ase/index.html
.......... http://www.marlincrawler.com/docs/dualcase/install.html
Doubler Adapter for Toy Autos: http://www.gearslug.com/index.php
Double NP Cases: http://medusa.ih8mud.com/NP205/Doubler.html
.......... http://www.offroaddesign.com/catalog/doubler.htm
Toy Cases Info: http://www.fourwheeler.com/techartic...ase/index.html
.......... http://www.off-roadweb.com/tech/0607...des/index.html
NP Cases Info: http://www.off-road.com/chevy/tech/transfercaseguide/
4Runner/Pickup Suspensions and Lifts:
SASing: https://www.yotatech.com/forums/f88/solid-axle-swap-has-begun-73430/
.......... https://www.yotatech.com/forums/f88/dirt-cheap-sas-well-close-73882/
.......... http://www.tacomaterritory.com/forum...isplay.php?f=7
.......... http://www.toyotaoffroad.com/Article...kleman_SAS.htm
Toyota Rear Springs up Front: http://www.pirate4x4.com/forum/showthread.php?t=265669
Chevy 63" Rear Swap: https://www.yotatech.com/forums/f31/chevy-63s-87-runner-71759/
.......... http://www.pirate4x4.com/tech/chevyswap/index.html
.......... http://www.pirate4x4.com/forum/showt...threadid=20665
4Links: http://4wheeloffroad.com/techarticle...131_0306_link/
.......... http://www.4wheeloffroad.com/techart...ension_part_2/
Coil Conversions: https://www.yotatech.com/forums/f88/finishing-coiled-over-idea-105460/
.......... http://www.offroadsolutions.com/susp...#7995_coilover
Body Lift + Flat belly: http://www.4x4wire.com/toyota/tech/drivetrain_lift/
.......... http://www.4crawler.com/4x4/CheapTri...ft/index.shtml
FZJ80 Suspensions and Lifts:
Body Lifts:http://forum.ih8mud.com/80-series-te...body-lift.html
.......... http://forum.ih8mud.com/80-series-te...body-lift.html
4Runner/Pickup Steering:
.......... Rebuiding Stock: http://web.archive.org/web/200503220.../taco/box.html
FZJ80 Steering:
Winches/Winching: http://www.pirate4x4.com/tech/billav...ery/index.html
4Runner/Pickup Rear Bumper Design
.......... Mulit-mount: https://www.yotatech.com/forums/f88/front-tube-bumper-multi-mount-winch-87892/
Vendors: (NOTE: I have no connection to any of these, they are provided merely for reference)
ARMOR - Front Bumpers:
..... 4Runner/Pickup:
..... FZJ80: Slee Offroad: http://www.sleeoffroad.com/products/...s_80series.htm
ARMOR - Sliders
..... FZJ80: Slee Offroad: http://www.sleeoffroad.com/products/...iders_main.htm
..... .......... 4xInnovations: http://www.4xinnovations.com/pages/guarding/sliders.htm
..... .......... Hanna Quality: http://www.hannaquality.com/products.html
..... .......... Man-A-Fre: http://www.man-a-fre.com/feature_ite...ocksliders.htm
..... .......... Iron Pig Off Road: http://www.ironpigoffroad.com/armor/sliders.shtml
ARMOR - Rear Bumpers:
..... FZJ80: 4x4Labs: http://www.4x4labs.com/bumpers.shtml
..... .......... Slee Offroad: http://www.sleeoffroad.com/products/...s_80series.htm
..... .......... Iron Pig Off Road: http://www.ironpigoffroad.com/armor/rearbumpers.shtml
AXLES/GEARS/DIFF PARTS:
..... FZJ80:
LIFT KITS - Body:
..... FZJ80:
LIFT KITS - Suspension:
..... FZJ80:
GENERAL MODEL SPECIFIC GOODIES:
..... FZJ80:
OTHER PARTS:
Aux Switches: http://4x4mods.com/Product/Jeep/Rock...rswitch40.html
Online FSMs
AXLES:
Lockers:
Chevy 350:
Transfer Cases:
FZJ80 Steering:
ARMOR - Sliders
..... FZJ80:
LIFT KITS - Body:
..... FZJ80:
..... FZJ80:
..... FZJ80:
OTHER PARTS:
no problem... i tend to update it every now and again when i find new stuff... if anyone finds any bad links, let me know, or if they find any links to add, or information to add, please PM me and i'll get it added right away!
runnermedic
13
Sep 21, 2015 05:20 PM
FS[SouthEast]: Brand new 26 mm. Downey torsion bars
HiLuxer
Sep 9, 2015 02:43 PM
zz_denis
Sep 6, 2015 03:43 PM
kelly1450
Sep 2, 2015 12:29 PM
