FJ Cruiser 2007 & on
FJ Specifications
Old Jan 18, 2006 | 12:07 AM
Good Times's Avatar
FJ Specifications
For all of ya lazy folks that don't want to bother with the flash presentation on Toyota.
Click here
Old Jan 18, 2006 | 06:42 AM
Jared's Avatar
Click here
Thanks.
Only 9.6 inches of ground clearance for the 4wd version, what is the world coming to?
No more are the days of seeing Trucks/Suv's with 12 inches of clearance, stock. It sure will kick butt with that V-6 and it's lighter weight though.
Old Jan 18, 2006 | 04:20 PM
tulsa_97SR5's Avatar
Originally Posted by Jared
Thanks.
I think that has a lot to do with how they measure. 31" tires are going to be 15.5" to the center of the wheel, so to get 12" clearance at the bottom of the diff it could only be 3.5" down from the center of the wheel. Don't think I've seen that except for portals. Or maybe IFS + IRS
Old Jan 19, 2006 | 11:44 AM
Flamedx4's Avatar
Yep. Even the ol' solid axle everyone is so gaga about had 7.7" from the ground to the diff.
1987 4Runner brouchure
Ground Clearance
Angle of approach 37
Angle of departure 22.5
Differential system to ground 7.7
Running ground clearance 10.6
Now what the hell do you suppose 'running ground clearance' is? The highest single place under the vehicle where you could run over an obstactle? I doubt it with IFS, the IFS skid would be about on par with the bottom of the rear diff, and nothing in the front would be any higher up than that.
Old Jan 19, 2006 | 11:48 AM
Flamedx4's Avatar
Thanks.
Hopefully you were just making a joke. (The tongue in cheek icon was invisible...)
No full size truck ever had 12 inches of clearance. They are all around 7.5 ish, always were. Today the Dodge Ram 3/4 ton with the optional biggest tires is 9.5". What a crime...
Ditch Doc
Oct 27, 2015 03:20 PM
zombie_barbarossa
Oct 2, 2015 10:54 PM
irv
Sep 29, 2015 01:04 PM
myotherrideisayoshi
Sep 29, 2015 05:41 AM
