FJ Cruiser SAS = Done!
Nice... the way Toyota should have made them to begin with.
Guessing that's a Rock Logic sway bar in the back. How is it working for you? What benefits have you noticed? All off road... or better road manners?
Nice, clean install. Love the coilovers! For some reason, (I'm not sure if it was the fact that the shock reservoirs had to be mounted on top of the engine) I don't think that the Solid Front axle was a match made in heaven for the FJ Cruiser. Just my opinion, but I do give you 10/10 on the CLEAN install. Looks bitchin!
Personally I think the Toyota 8" is a great axle. Very easy to work on, especially with the drop out third members.
#25
#28
Sure! When you drop off your FJC, just leave a big pile of cash with it.
It's actually the Currie Anti-Rock sway bar. I've only put about 200 miles on it since the build, so I can't really say much about the sway bar yet. I'm re-valving the Fox shocks this week and have to wire up the front elocker and winch. Then I'm wheeling the Rubicon at the end of the month. After that I should know more about how the sway bar works. The folks at Currie swore up and down that it would help on the street and would not limit articulation offroad. I'll run it with and without the sway bar connected to see what works best.
I like your avatar better...
#37
Thanks Corey. I'm going to pull the front shocks in the next week or so and re-valve them a little firmer on the compression stroke. Then I will play with the air bump oil levels and air pressure, but really all I'm doing now is tweaking things a little. I'm very pleased with how it worked yesterday on its first real run.
#40
Co-Founder/Administrator
A vendor over on the big FJ site is selling these.
https://www.yotatech.com/forums/f153...-racks-128892/
I got in on the group buy, mine arrive tomorrow.
They are military type bags that hook to a rack on the rear door, and also you get pouches for the front doors and the cubby hole where the factory sub goes.
Here is some more info too.
https://www.yotatech.com/50652541-post22.html
