Will 32 x 11.50s fit on factory rims w/o rubbing?
I have a 1996 T100 with factory steel rims. The current tires are 31 x 10.50 x 15s. I'd like to go up one size in tire. Does anyone know if the 32 x 11.50 x 15 will fit on the factory rims? Do you think they'll rub (I have no lift kit, just factory suspension with Rancho 5000 shocks). There seems to be plenty of room, but I just wasn't sure. Thanks for the help.
Thanks. Are all the factory rims 8 inches wide for the '96 T100? I have my rims at the powder coat place right now so I can't measure them. I'd like to know in case I have to change my order at the tire shop.
Thanks
Thanks
I'm runnig 32X10.5 (265/70/R17) on my T100. They just barely rub sometimes on the top of the mud flaps. my wheels are 17x8 (I think) sequoia wheels. you should have no problem running them on yours. BTW, I'm running no lift. strictly oem stuff.
I cranked my tbars all the way up, removed the mudflap and trimmed the bumper valance, and I rubbed quite a bit with 32x10.50 r15 swampers as well as 305 75 16 MTRs
I don't think this is correct advice...
Why not run 39"? Or 44"? Hell, why not 52" Michelin?! Just a little trimming is all you need!
this topic has been covered 450x over, hence my facetious comments.
265's have been said to be 31's on a website, but when placed side-by-side with a 33" tire it is identical so... ya
And lets do a test, go park on a flat surface, take a measuring tape and tell me what you ground clearance is(lowest point on the vehicle) mine went from 9.5 to 10.5 and from what i understand, for every inch of tire size (31"-32") you gain .5 of an inch for ground clearance.
cause i ran 31"x10.5" Pro Comp Xterrain and they are AMAZINGLY smaller to the 265's that ARE THE SAME SIZE WHEN PLACED NEXT TO 33'S.
Looking at the 31 X 10.5 Pro Comp Xterrains, they are only 30.5" diameter ( http://www.procomptires.com/xterrain2.html ). So you really picked up 1.3", or .65" under the tire.
Didn't mean to start a fight!
Thanks for all the opinions. I did try searching all the past posts and really couldn't find an answer to my exact situation. That's why I went ahead and posted the question. Sorry if it bugged people as repeat question.
Wow.
