93-98 T100s All T100 trucks
tach problem
Old Dec 28, 2009 | 02:57 PM
t100ist's Avatar
tach problem
one day i was driving down the street and the needle started to jump up and down and i thought it wasn't a big deal so i kept on driving and then it just sunk to the bottom then my check engine light went on and then i checked it and it said i needed to get a new speed sensor so i got one and installed it and still the tach still doesn't work
Old Dec 29, 2009 | 10:08 AM
BamZipPow's Avatar
What's the specs on yer T-100? Year, engine, transmission, etc...
Is this the stock tachometer or an aftermarket one? Are you the original owner? Has this T-100 been modified? Did you check the wiring? Are you sure the tach still works? Did you test the signal from the ECU?
toyotamonster
3.4 Swaps
7
Apr 16, 2020 06:02 PM
altydog
Jul 28, 2015 10:20 AM
Logz808
Jul 26, 2015 07:09 AM
Jonny246
Jul 24, 2015 12:37 PM
kyletbert
Jul 17, 2015 11:39 AM
