93-98 T100s All T100 trucks
Questions about Jacobs Milage Master Ignition system
Old Sep 20, 2008 | 01:02 PM
bayouguy327's Avatar
I recently got this ignition system from a friend who could not use it on his vehicle because of other issues with his engine. I was wondering if anyone knew anything about it and would know which application to use when installing the system. It also talked about a Jacobs modified distributor cap, which jacobs does not have. Any input would be greatly appreciated.
Thanks,
Chris
Old Sep 20, 2008 | 09:02 PM
taikowaza's Avatar
You'll need a Jacobs secondary trigger. Your stock distributor cap should be fine.
the secondary trigger goes between your stock ignition and the jacobs mileage master brain.
The brain triggers the super coil which hits your distributor cap. You can read a lot about Jacob's systems here on yotatech. Good luck! Ganoid knows a lot about them too.
[IMG] Click for full size - Uploaded with plasq's Skitch[/IMG]
Sleaker
Aug 26, 2020 06:03 AM
TURBOrunnerNM
Jul 22, 2015 11:01 AM
nickb3
Jul 21, 2015 10:00 AM
rushw
Jul 18, 2015 01:46 PM
94whiterunner
Jul 12, 2015 07:15 PM
