93-98 T100s All T100 trucks
New to Me 1996 T100 Xcab 5 Speed 4x4 for my DD
Old Jun 23, 2018 | 07:29 PM
SnowChad's Avatar
I recently purchased a 1996 T100 extended cab 4x4 5 speed that I am going to use as my daily driver. I have it torn apart in my garage at this time. Tranny is out and just received the new Aisin clutch/pressure plate. I partially dropped front axle to replace oil pan due to rust. Cracked clutch pedal bracket is being fixed and firewall reinforcement being done. Bed is off, so I can clean up the rear frame and apply Chassis Saver to entire frame.. While bed is off, I am going to add an extra leaf spring to each side. Body in very good condition. Frame is in great condition as best I can see. Interior is in great condition also. Truck has 145,000 miles with 3.4L. I have 2 weeks to finish putting this back together and I am very eager to start driving it!
Attached Thumbnails New to Me 1996 T100 Xcab 5 Speed 4x4 for my DD-t100-2.jpeg   New to Me 1996 T100 Xcab 5 Speed 4x4 for my DD-t100-3.jpeg   New to Me 1996 T100 Xcab 5 Speed 4x4 for my DD-t100-1.jpeg   New to Me 1996 T100 Xcab 5 Speed 4x4 for my DD-t100.jpeg
Old Jun 30, 2018 | 02:06 PM
SnowChad's Avatar
Presently working on replacing brake/fuel lines. I have already added an extra leaf spring to the rear with new u bolts. Frame to be wire brushed tomorrow and then brushing on Chassis Saver. Fuel tank is off and in great condition! Having fun figuring it out.
Old Jun 30, 2018 | 02:08 PM
SnowChad's Avatar
Alloy wheel lug nuts?
I purchased alloy rims from a 2007 Tacoma. Will the lug nuts from my current steel rims work on the alloy rims?
Old Jun 30, 2018 | 07:13 PM
dropzone's Avatar
Fossilized
If the alloys from the 07 are like the rims from my old 05 Taco than you will need different lug nuts..pretty sure they were stepped with a thin washer built in.
google example of rim I had
Austin Marr
3.4 Swaps
21
Dec 30, 2015 06:40 AM
ingenuitor
Jun 26, 2013 03:45 AM
crash66030
Jun 10, 2012 01:55 PM
Sizzler
Dec 31, 2006 07:50 PM
