Lifting my 1997 Toyota T100 4wd 3.4L Extended Cab
I can't seem to find a lift kit built for a t100 I want to put a set of 35's on my truck so I was going to lift it 6 inches In The back and 7 in the front. Any ideas? I really would preffer not putting blocks on the leaf springs and turning up my bars in the front.
Superlift and others still make a kit. Google is your friend. http://www.rockymountainsusp.com/toyota4_T100.htm
You dont want blocks switch to chevy springs or get some springs added to your pack.
Also if you can fabricate stuff, pickup a used lift for a the older 86-95 truck off ebay or craiglist. Can modify or use them to build your own lift very easy. T100 uses same front suspension, just wider brackets.
zd92655
Mar 6, 2022 12:58 PM
dirtrider0129
10
Jun 24, 2015 12:24 PM
