93-98 T100s All T100 trucks
Help.
Old Dec 11, 2012 | 12:54 PM
eyepoke's Avatar
No power steering stalling out in neutral
I have a 98 t100 4x4 5speed manual.
a day ago it was stalling out in idle and reverse.
today my power steering went out while i was driving. are these 2 seperate problems or is my power steering pump out causing the low rpms? I have no clue where to start
Old Dec 11, 2012 | 05:05 PM
trythis's Avatar
Welcome!
Could you go back and change your topic title? You may get more responses to your question. "Help" is a bit vague.
I cant remember if we have serpentine belts or individual belts. But if you can take teh power steering pump offline that would answer your question.
Old Dec 12, 2012 | 09:35 AM
250000_yota's Avatar
The stalling could be due to the pump. There is a switch on the pump that bumps up the idle so the motor doesn't stall when the power steering is used if the pump was failing, it might not have been putting enough pressure to trigger the switch.
zytra
Jan 24, 2019 03:16 PM
Firefightersink15
Nov 23, 2015 10:32 PM
Shagool22
Sep 28, 2015 07:53 PM
fountain
Sep 28, 2015 03:04 AM
LotOMiles
Sep 14, 2015 11:45 PM
