93-98 T100s All T100 trucks
Front Axle Removal?
Old Jun 20, 2008 | 02:11 PM
funnyguy44444's Avatar
Front Axle Removal?
Hi everyone,
The front left CV joint boot on my 95 T100 Xtra Cab 4wd is broken and i want to replace it asap. My question is how difficult is it to remove the front half axle so i can put a new boot on. I know its not real easy but just wanted some insight on how hard it really is. Thanks a lot.
Old Jun 21, 2008 | 08:14 PM
Froggy93's Avatar
They aren't to bad to do. but, just be ready to put in some new sway bar end links. when I did mine, I couldn't get the axle out without disconnecting the sway bar end links. they were rusty so needless to say, they broke.
Old Jun 23, 2008 | 02:49 PM
Yup i already am planning on replacing those. How long would you guess it would take?
Old Jun 23, 2008 | 03:31 PM
Team420's Avatar
actually...if u unbolt the sway bar from the frame, on both sides....u wont need to discon the end links. the sway bar will drop down, and u will have plenty of room to work with...they r not that bad...I replaced both of mine in about 3-4 hrs.
Old Jun 25, 2008 | 06:19 PM
Froggy93's Avatar
yeah it didn't take to long to probably about 1 1/2 to 2 hours. granyed I had a lift and stuff to do mine. and I wasn't in a big hurry either.
Old Jul 5, 2008 | 07:25 AM
becaron's Avatar
I did them on my 4-runner, and all I did was take the lower shock bolt out. I never touched the sway bar. I had a jack under the lower balljoint to change the angle the arms set at. That help get them out easier.
88sasturbotoy
Jan 30, 2026 01:57 PM
oldirtydirt
Feb 23, 2020 09:30 AM
jerusry
Oct 19, 2015 05:28 PM
deepmarsh
Aug 6, 2015 03:44 AM
ItsJustD
Jul 7, 2015 07:49 AM
