93-98 T100s All T100 trucks
Brakes/Rotors on T100
Old Sep 4, 2006 | 08:33 PM
CJM's Avatar
CJM
My front rotors from the previous owner are quite bad. The brakes are ok and have about 10k left I estimate but the rotors-specially the passenger one has 2 nice gouges in it. I assume the previous owner never replaced them or didnt care to.
Now, my question is upon removing the tire I need to remove the manual warn hubs to get at the rotor. Is it a solid unit I can unbolt or will a ton of (tiny) parts come out when I do this. I am quite expieranced in doing a brake jobs, but none on 4x4's. I just worry if when I remove the hub it doesnt come out in one piece and I need to reassemble it.
I found this tuturial that seems like it would worke even though I have warn manaul hubs: http://personal.utulsa.edu/~nathan-b...14freewhee.pdf
Old Sep 5, 2006 | 09:52 AM
CJM's Avatar
CJM
C'mon no one knows? The hub assembly is exactly the same as a mini pickup, somebody must know??
Old Sep 6, 2006 | 10:57 AM
tickt9842's Avatar
what year is your t100?
Old Sep 6, 2006 | 11:53 AM
snap-on's Avatar
the lock out hub should come off with out haveing to take it apart.
Old Sep 6, 2006 | 05:06 PM
CJM's Avatar
CJM
Its a 96 x-cab sr5 4x4.
So it should all just come out easy as pie and go back together easy?
Old Sep 13, 2006 | 03:41 PM
alwayssearchin's Avatar
the hub will come out, but if the truck stops good with no vibration wait until you change the pads, it'll be ok.
stanz
Oct 30, 2015 10:33 AM
toyhaulert100
Sep 24, 2015 07:55 PM
tallsasquatch
Sep 20, 2015 02:48 PM
mat
Sep 17, 2015 11:18 PM
Tcsdef
Sep 7, 2015 11:17 PM
