93-98 T100s All T100 trucks
Advice on Finding a Short
Old Feb 19, 2012 | 07:58 AM
FoCo_4_Low's Avatar
Hi Guys!
So this post is an extension of an older one (erratic cold idle). I have finally been able to conclusively determine that the reason why my truck is idling so erratically is that there is a short between the engine coolant temp. sensor and brake circuits (not sure which brake circuit, just know it has to be one that gets powered when you hit the brakes). Does anyone have any good advice on finding this short. I have a service manual with a wiring diagram already. Just wondering if there is any way to locate it without having to try to trace the wires up over around and through everything the engine bay.
Old Feb 21, 2012 | 06:25 PM
BamZipPow's Avatar
You wouldn't happen to have a trailer light adapter installed would you?
Have you tested the brake switch yet? Do you have cruise control?
Old Feb 21, 2012 | 07:18 PM
FoCo_4_Low's Avatar
I do have a trailer light adapter and cruise control. Brake switch? Would that be the one operated by the pedal to turn the lights on?
Old Feb 24, 2012 | 02:23 PM
BamZipPow's Avatar
The trailer light adapter could be shorting out and causing yer electrical gremlins. Try removing the adapter and see if the problem still exists. Those adapters are a known electrical gremlin creator...when they go bad.
Those vehicles with cruise control vs those that don't have a different brake light switch. You must make sure you replace it (if it's bad) with the same type. A non-cruise control brake switch won't work...
snosurfer
3.4 Swaps
Aug 15, 2024 02:11 AM
icentropy
Sep 16, 2020 02:47 PM
nanhodges2733
May 29, 2020 03:28 PM
Eggslinger
Jun 8, 2019 03:32 PM
Huntingtruckcletus
Jul 8, 2015 05:26 PM
