93-98 T100s All T100 trucks
95 t100 3.4 No start - has fuel/spark
Old Mar 9, 2018 | 11:25 AM
MCMICHEM's Avatar
I posted this on accident in the 86-95 pickup forum so am reposting here.
I have a 95 T100 3.4L with 255k Miles on it that slowly died and quit running. It sat over the winter and I would start it weekly when home and every week it got worse, ran rich, misfired and eventually I had to hold the throttle down to keep it running until one day it finally stopped.
The timing was jumped and 45 degrees off on each cam pully so I did the timing belt and the following.
Coils
plugs
wires
fuel pump (Wired Directly to battery at 12v to rule out short in the wiring as it never seemed to have an audible prime and iut turned out I wasnt getting fuel to the rail)
Fuel Filter (Looks original and full of pitch black fuel)
Timing belt kit
Checked my cam/crank sensors and they meet spec.
What I am running into now is 2 problems
1. I still have yellow (I'm assuming to weak) spark after replacing those ignition components.The plugs constantly get soaked in fuel that almost has a white color to it like its full of air...
2. Even though the plugs get soaked while trying to crank the vehicle, if i squirt fuel down the throttle body with OR without the fuel pump running, it will instantly start and then die after the fuel is gone.
Im buying a compression tester in the next few days to check compression thinking maybe I washed the cylinders and possibly swapping out a fuel pressure regulator just to try it, but this fuel issue has me stumped.
I would REALLY appreciate any help because I have been fighting this thing for months with no luck.
AustinMyers
Jan 23, 2016 09:10 AM
Jackedupjoe
Jan 2, 2013 03:32 AM
juicyj444
Dec 24, 2011 02:27 PM
TheOrangeBomber21
Jun 27, 2011 07:39 AM
findlay.motorsports
Dec 31, 2008 01:41 AM
