93-98 T100s All T100 trucks
86bedlesstoy's T100 build
Old Feb 17, 2014 | 10:49 PM
Zpd426's Avatar
use direct link for photobucket i think.
Old Feb 18, 2014 | 02:24 AM
jaretstuff's Avatar
It should give you 4 different options for codes. Use the IMG one
Old Feb 19, 2014 | 10:06 PM
86bedlesstoy's Avatar
Thinking of trans temp gauge install on the a-pillar. Anybody done this?
Old Feb 20, 2014 | 08:55 PM
Size:  80.1 KBBought these today! On sale and couldn't pass it up. Have always wanted some nice off road lights for the bumper. Be sure to check out my Install in the coming week or so.
Old Feb 21, 2014 | 02:47 PM
  #25
To my previous statement about the jumpy hood I wasn't talking about the bracing coming apart. I was referring to my hood latch being loose. Can pull up on the hood and it moves a small amount.
Old Feb 21, 2014 | 05:20 PM
  #26
Old Feb 25, 2014 | 02:27 PM
  #27
Got my HID kit installed today, Wish I had a projector set up for it. There is NO aftermarket for these truck so it makes it hard.
Old Mar 12, 2014 | 10:07 PM
  #28
Fixed the jumpy hood with some wraps of electrical tape on the latch. Got the rear LEER window installed on my topper, walked past my truck twice now not realizing. Now I went to open my tail gate and the plastic broke. Just something else to fix. Why were they not re-enforced with metal?
Old Mar 20, 2014 | 08:39 PM
  #29
KC headlight install!
Hey guys, finally got around to installing my Long Range KC-Hi Lights SLIM kit.
Had been looking at my blank cover here and decided it needs a nice button for some flash.
Peeled the dash apart with 4 simple bolts for the lower half cover.
The SLIM lights worked perfect for mounting to stock bumper for sure!
The drilled out unused cover turned out great! Looks stockish for its placement.
All mounted up and looking great! Need some aiming but I will have to wait for night time. Already looking to fill that void in the grill another pair of lights.
Old May 25, 2014 | 06:54 PM
  #30
Layo's Avatar
Nice T bro. its nice to see another one in here. I almost did the same set up with the off road light but i end it up getting a grille guard. sorry about the picture size
Old Jun 25, 2014 | 08:12 PM
  #31
that is a nice T100! like those window covers and fenders
Old Jun 29, 2014 | 07:52 PM
  #32
Hey guys, went on a little rally around Summit today and have a loose steering shaft in between the pedals. Any hints as to what is to fault.
Old Jun 29, 2014 | 08:32 PM
  #33
CJM's Avatar
CJM
I recall there are several nuts you can tighten on the steering shaft both inside and outside. I know for a fact there is one on the outside near the steering box tho.
Old Jun 30, 2014 | 10:45 AM
  #34
Yep that's what I planned on doing. Thinking of ordering some 285/75r16 mt/r.. I could fit with a 1" bj spacer.
Old Jul 2, 2014 | 08:50 PM
  #35
Hey guys, been a while but really getting in to overland style camping. Looking in to a dual battery set up. looked all over the internet and found some useful information. Thinking of this set up here http://www.dfna.info/dual-battery-kit.html Let me know if anybody has another suggestion as well. Will also be installing bars to my topper for a Yakima Warrior Rack for a hi-lift and shovel along with other items as needed.. Possible camping awning in the back of my mind.
Thanks
Old Oct 10, 2014 | 12:20 PM
  #36
Went wheeling for some camping on my birthday Tuesday and changing my oil today I realized I have blown my passenger cv boot!
Old Oct 28, 2014 | 05:40 PM
  #37
With 140k now it's for sure time for a timing belt kit with water pump and tensioner since I'll already be in there. Would hate to do all that work then have my tensioner if it looses hydraulic pressure while driving at any speed.
Last edited by 86bedlesstoy; Oct 28, 2014 at 05:43 PM. Reason: personal spell check.
Old Oct 29, 2014 | 01:34 PM
  #38
CJM's Avatar
CJM
I did mine at 150k miles in. belt was fine, like literally no cracks no nothing. I know it was done around 120k since i have the paperwork from the previous owner. Everything was 100% in spec as well, which was nice. Only reason I even did it was the crank pulley separated. there is a metal puck like part that came out but the rest was fine. RTV the right stuff gray did the trick..300 for a pulley wasnt happening.
Old Dec 19, 2014 | 12:49 PM
  #39
Anybody have a time with your seat belts locking way too much!?!?
Old Dec 20, 2014 | 07:53 PM
  #40
CJM's Avatar
CJM
Yep, all the damn time..
