93-98 T100s All T100 trucks
1996 Toyota t100 low voltage o2 sensor
Old Jul 6, 2018 | 09:08 PM
Tyler Johnson's Avatar
Truck threw a code says low voltage on O2 sensor. Replaced it with a Bosch and is still sputtering low/rough idle like it was before acting almost like a misfire any advice helps thanks!
Old Jul 6, 2018 | 10:10 PM
75w90mantraN's Avatar
Check harness connector to fuse box/engine for dirt or corrosion...
Right sensor for particular engine and trans?
Low voltage can be high resistance in circuit...not necessarily the sensor though good to replace.
Old Jul 6, 2018 | 10:14 PM
Check harness connector to fuse box/engine for dirt or corrosion...give it a good cleaning with an acceptable cleaner.
Old Jul 7, 2018 | 10:28 AM
Is there a connector from the harness that connects to the fuse box? I am positive that it is the right sensor.
Old Jul 30, 2018 | 05:11 PM
A check on wiring diagrams shows connections up to the ECM for signal inputs and outputs, a splice somewhere and ground in the engine bay, and battery power (I believe white wire with red stripe) through the DLC? As far as pin slots, it will depend on whether yours is automatic or standard trans and the engine size. I can upload the schematic tomorrow.
Remind me, is this sensor pre- or post- cat?
Elliott Doyle
Nov 8, 2016 06:19 AM
Sabre2012
Aug 28, 2012 12:11 AM
WTAllstar
Jun 2, 2011 08:15 PM
tiethilo
Aug 12, 2008 02:59 PM
CILO
Feb 12, 2007 10:49 AM
