General Electrical & Lighting Related Topics Ask here for electrical, wiring, and lighting info for your rig that could apply to all years
Turn signals and marker lights don't work
Old Dec 1, 2009 | 01:22 PM
rsidner's Avatar
Angry Turn signals and marker lights don't work
- 1984 4runner w/ 1986-87 wiring harness
- My hazards and horn work fine.
- I've checked all of my fuses.
- They all worked before I installed more of the interior.
- My marker lights worked before without the dimmer hooked up.
- Tried connecting the dimmer but didn't help.
- When I flip on the marker lights I hear the circuit relay click but nothing happens.
Is there a common problem that causes this sort of issue past some strange wiring fault? Please help! I'm so close to finishing this and just want to get it on the road before it starts snowing. I'm at my whit's end.
Old Dec 1, 2009 | 08:52 PM
scyotapu's Avatar
do you have a voltage meter? see what kinda power you have running to plug at the bulb. maybe the bulbs are just bad, not likely but hey... who knows. let me know the voltage, if any is comming through the lines.
Old Dec 1, 2009 | 09:50 PM
olharleyman's Avatar
Did you check the main fuse on the passenger side fender under the hood? I had a similar experience once and it turned out to be the main 80 amp fuse blew had to replace it and every thing worked fine but you have to pull it by unscrewing the fuse from the fender.
Yota.Jay
Mar 6, 2016 11:02 PM
gog1968
Jun 22, 2015 05:55 AM
ShaunKris
Jun 17, 2015 04:33 PM
infinityisfive
Jun 16, 2015 06:51 PM
